96 PSD problems where to start
Old Mar 6, 2014 | 07:54 PM
7DF250's Avatar
7DF250
I have a 96 F-superduty 7.3 140k miles. Ran great gets regular oil changes along with everything else. Only issue was CPS that I swapped 6 months ago.
One morning it wouldn't start so I left it. The next morning it started but ran very rough but no smoke. For the past week or so when I would park on a down hill oil would drip down the front of the motor, quite a bit actually leaving a good spot on the ground.
The Ford fleet shop where I get most of my maint/work done says:
1. Replace 4 injectors
2. Reseal oil cooler
3. Pull motor and replace warped oil pan (not happening)
4. No codes so no clue.
The powerstroke experts at work say the IPR is leaking into the valley, that's the oil leak, and lower psi is rough running. Others say EBV, or valve cover gasket harness fried.
Where do I start???
Old Mar 6, 2014 | 08:11 PM
ReBilld's Avatar
ReBilld
Check the HPO lines and fittings going from the pump to the heads.
Old Mar 6, 2014 | 10:45 PM
oldbird1965's Avatar
oldbird1965
Just clean everything up, then look for the leak.
stxbrowneyes
Aug 14, 2013 07:47 PM
Diesel 724
Sep 3, 2011 08:37 AM
Deerslayinrenek
Apr 12, 2011 11:15 PM
sticks25
Mar 23, 2011 12:11 AM
irwheel
Apr 14, 2004 10:53 PM
