When I got a hold of my 77 f150 custom, I came without a radio but it has a square 9 prong connector in the dash most likely not stock? I just ordered a stereo to put in but I'm not sure on what the wires are on the current connector, could someone give me some info?
That's going to be some custom connector from a radio manufacturer. Pioneer, JVC, etc. all have their own custom pigtail that comes with radios that you splice into factory wiring (and in the case of these trucks, run additional wiring). Unless the previous radio in this truck happens to be the same manufacturer as your new radio, and the pigtail was installed correctly in the first place, you should peel everything back to original and start over. I wouldn't add onto this pigtail because you would be splicing on top of a splice.
The OEM radio was powered by a GREEN 2-terminal pigtail. YELLOW with a BLACK stripe is switched power, BLUE with RED stripe is dash illumination. Do not mistake the BLUE with RED stripe wire for ground. The OEM radio grounded through its mounting chassis. The speakers were connected over a separate pigtail.
there are two wires that go to the ignition wireing harness behind the wheel. I put my voltage meter on the two and was getting 12 volts, Is this the correct wire to use for the radio power? It was only getting power when the key was in the on position.
For My constant +12v Wire, I replaced the cigarette lighter with one that had both a spade connector, as well as the factory connector, Reconnected the factory wire to the factory connector, then used the spade connector for a point to connect my constant +12v. this way it's also fused through the courtesy fuse in the event of a short.
If you're planning on going loud, here's whats worked for me in the past. Solder each connection together, and cover individually with heat shrink tubing. once you have all your wires, wrap the whole bundle in electrical tape, well past the splices on either end.
I would not look for any constant hot wire from anything that has to do with the headlights. They are on a wiring set up that is not the best design anyway.
Look for a yellow 3 holed plug behind the left side of the dash, or that might be keyed power, I am not sure.
See the PDF attachment see 18C617 where is has a circle around it? And it shows a 2 arrow lines going to a 3 hole plug? It it at the steering column V support bracket, ck it for constant power?
Theres a wire going to the high beam switch. Its a thick red one. Is this my constant 12 volt wire?
No, steer clear of the headlights. GREEN with YELLOW stripe wiring is hot-at-all-times power for the courtesy lamp circuit. Use that. There is a 3-connector pigtail behind the glovebox (which also goes on to power the cigarette lighter). The connector in the picture above is hot-in-ACC keyed accessory power.
I'm telling you what specific wire colors you must use. It doesn't work the other way around - you pick wires and have me answer yes/no. I already explained that the pigtail the PO left was for a previous aftermarket radio, and should be removed such that you can start over.
The aforementioned pigtail IS there, but you may not see it by peeking under the dash. You may have to loosen the glove box.
Ok I looked behind the glovebox and found a connection the goes off the green and yellow, I'm guessing this is the stock radio wire or the glovebox light. I will use this wire
