1978 - 1996 Big Bronco
87 Bronco temp fluctuating
Old Mar 5, 2014 | 04:31 PM
tyler.purrington's Avatar
tyler.purrington
I had this problem last year and still cannot figure it out. My 87 Bronco XLT 5.0 AOD runs at around 180-190 but randomly when i am driving or i accelerate it will jump up to 200-205. I have mechanical guages. Last year i replaced the water pump, t-stat, radiator, all of the hoses. I was thinking a blown head gasket but no water in oil or oil and water. Any help?
Old Mar 5, 2014 | 05:43 PM
Bubba Jones's Avatar
Bubba Jones
Well it sounds like you may have air in the system from when all that work was done. I would first check to make sure the coolant system is filled fully first. I know my system would sometimes jump around like that because it ended up there was some air in the system. It can take some time to get it all out.
Otherwise, if there is no air in the system, potentially your fan clutch is going out. However I believe that would demonstrate more persistent symptoms.
Old Mar 5, 2014 | 05:49 PM
tyler.purrington
I don't think air is in the system b/c I have flushed and burped several times, also changed the fan clutch when i changed the water pump
Old Mar 5, 2014 | 07:24 PM
Ian27's Avatar
Ian27
Fluctuating temp
I have been noticing the same thing
willydub
3.8 & 4.2L V6
Apr 26, 2015 02:00 AM
willydub
1997 - 2003 F150
Feb 27, 2015 09:00 PM
parkland
6.4L Power Stroke Diesel
Jun 9, 2011 11:50 AM
f350on38s
16
Oct 12, 2010 09:55 PM
rkersh409
15
Oct 2, 2004 04:14 PM
