Sponsored by: Real Truck
2000 F350 Engine Problems
Old Mar 5, 2014 | 10:41 AM
dirtbikeflyboy917's Avatar
dirtbikeflyboy917
I have a 2000 F350 4x4 with 7.3L diesel and a manual transmission. While driving home yesterday my gauges (fuel, temp, volts, oil pres) stopped working. Within a couple min the speedometer and the tach also stopped working, but the truck was still running fine. Within a couple miles the engine stopped running, just like I had turned the engine off.
After having it towed home I checked all the fuses, none are blown, but there is no power to fuse #16 (15A, instrument cluster, high beam head lamp). Also in the fuse box under the hood, again, no fuses are blown, but fuse #9 (left head lamp low beam) and #11 (right head lamp low beam) have no power to them.
any help would be greatly appreciated.
Old Mar 5, 2014 | 02:18 PM
spongecop's Avatar
spongecop
Semper Fi
disconnect both batteries and remove the fuse box so you can inspect the rear. Your front windshield may be leaking and causing corrosion. Common issue
Old Mar 5, 2014 | 03:53 PM
DavidB's Avatar
DavidB
Those fuses will have no power to either side unless the lights are turned on.
Old Mar 16, 2015 | 10:00 AM
dirtbikeflyboy917
Thank you for that information.
powerstrokeLLY
May 3, 2021 07:42 PM
thegrit
Mar 21, 2015 06:01 AM
9228.bobcat
6.7L Power Stroke Diesel
Jun 11, 2013 12:44 PM
cdownin
Mar 19, 2012 09:42 PM
