blue spring upgrade??
Old Mar 4, 2014 | 10:56 PM
diggintrenches's Avatar
diggintrenches
Hmm, where do you buy the Archoil 9100?
Old Mar 4, 2014 | 11:10 PM
tofargone's Avatar
tofargone
O sorry I was talking about the blue Spring that i think i saw on ebay for like $65 or something like that im still looking for the 9100
Old Mar 5, 2014 | 04:54 AM
Money-Pit's Avatar
Money-Pit
Here you go. The 9100 goes in the engine oil, and
6200 is a fuel treatment. You need to at least get a 16 oz jug of 9100, as you add 1 oz per qt of oil.
Archoil
Old Mar 5, 2014 | 05:04 AM
Money-Pit's Avatar
Money-Pit
Riffraff Diesel Performance - Search Results for "blue spring ford fuel pressure kit"
the first 2 items are blue spring kits. One with cover, one without. The kit with cover also has "something I can't remember" included. I think it's the plastic piece.
sorry, just woke up and groggy...
Old Dec 14, 2019 | 10:04 AM
Bill Adams's Avatar
Bill Adams
Use FIMOCO or name brand?
I have fuel leak on side of filter.
Seems like a good time to upgrade to the blue spring.
Is there enough difference between the generic or FOMOCO for 20$ and the Sinister or Bullet proof for 75 to spend the extra money?
Old Dec 14, 2019 | 10:15 AM
F350 1990's Avatar
F350 1990
Bill -- the generic Motorcraft stuff will always raise fuel pressure PLENTY and the other stuff is overkill, total waste of money on stock trucks.
As for your leak, likely the crush (or seal) washers at the banjo (supply side on 2004 and above or a ORFS (oring faced) on 2003), feeds (ORFS) heading to the cylinder heads or that return line (least likely of the candidates)..... there are two orings on the ORFS connections (a small and a larger oring) and always replace with Viton................I also use a quality thread sealant as backup protection -- preferably high temp or the aviation variants....
Old Dec 14, 2019 | 11:17 AM
Bill Adams's Avatar
Bill Adams
Thanks!
Thanks!
I’m ordering a midrange priced one.
Kit includes the o-ring for the inlet line, which I was suspecting. The leak is definitely on that side of the filter.
Old Dec 15, 2019 | 11:29 PM
Fuzzpuss's Avatar
Fuzzpuss
I recommend ordering it through a Ford house (like White Bear Lake) to be sure it's a real Motorcraft, as opposed to Amazon, which is becoming more like a Chinese market by the day.
Old Dec 16, 2019 | 12:45 PM
HT32BSX115's Avatar
HT32BSX115
Originally Posted by LivingLarge
Yes, at idle it went from 52 to 68... Now I'm wondering what that does to fuel economy at idle?
Mileage is more a function of your right foot than low pressure fuel to the injector rails.
w_huisman
Mar 19, 2024 07:27 AM
WH 6.0
Aug 6, 2012 09:05 PM
GeneLaw1
Jan 4, 2012 02:58 PM
dan.alger
Apr 9, 2011 06:55 AM
DSMMH
Feb 19, 2010 10:03 PM
