390 starting woes
Old Mar 2, 2014 | 07:54 PM
JohnnyLogic's Avatar
JohnnyLogic
390 starting woes
I have a 73 F-250 with a 390 that was tuned up six months ago by my mechanic. He put in a new carb which I believe is a Motorcraft 2100. After the tune up the truck ran perfect, very smooth. About a month ago I began to notice after a cold start-up the truck would idle fine and then abruptly quit. It would start back up after quitting just fine. This weekend I can hardly get the truck to start. Initial start-up while cold is good but very soon after the engine stops. If I try to restart I get a lot of dieseling, rough idle, and the engine stops. I also had some white smoke belch out of the carb. My procedure for starting is to give the accelerator a couple of pumps and then crank the key. Any ideas on where to start troubleshooting. I'm no auto mechanic, but I am mechanically inclined.
Old Mar 2, 2014 | 10:01 PM
crop harvester's Avatar
crop harvester
If your distributor is the points type I woulld check the point gap and or try changing the condensor,inspect cap for cracks.
Old Mar 2, 2014 | 10:33 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe
One of the first things I did after I got my '73 with 390 was to get a "points eliminator" kit to replace the points and condenser. The Accel kit is about $65 from the parts store and now I never have to worry about re-gapping points periodically.
The kit was unbelievably simple to install and the truck fired up immediately on the first turn when finished. Starting since then has been faultless. It didn't "improve" the performance significanly, but it is definitely more consistent/reliable.
Old Mar 3, 2014 | 07:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Once it gets past the cold stage, does it run good or does it just keep running like crap?
Old Mar 3, 2014 | 10:42 AM
Filthy Beast's Avatar
Filthy Beast
Agree on checking points gap - 0.017" I believe.
Points plate solid? No abnormal play? Distributor wobbly? The hold down bolt snugged up good?
Take the air cleaner off and take a peek down the carb throat....blip the throttle...get a good squirt of gas?
Do you have fuel filters before the fuel pump and after? They in good shape - not gunked up?
Vacuum lines all good and connected?
Choke in good workable condition?
Old Mar 3, 2014 | 01:32 PM
JohnnyLogic
I haven't been able to get it to run long enough to get it to normal op. temp.
Old Mar 3, 2014 | 01:55 PM
MIKES 68 F100's Avatar
MIKES 68 F100
if it continues after points condenser change replace the coil , they act real weird when going bad
Old Mar 3, 2014 | 07:00 PM
69cj's Avatar
69cj
Stuck choke, defective float or points or timing. Sorta sounds like a fuel problem with the info supplied.
Old Mar 5, 2014 | 06:42 PM
JohnnyLogic
Thanks for the replies...
Old Mar 5, 2014 | 07:22 PM
69cj's Avatar
69cj
No offense but your pics do nothing to determine the condition or setting of the points.
Old Mar 13, 2014 | 11:00 PM
orich's Avatar
orich
Aw sounds like the choke pull off diaphragm. It located on top of the carb (3) small bolt 1/4"type screws. If this if good it sucks in pulling the choke open enough to start & run.
When this little pull off diaphragm fails the chokes stays on full not letting the engine to start up an run. This is on the top of carb just behind the choke butterfly flap.
Remover air filter find the area in reverence i'm talking about then try to starting to motor. Looking between cowl & hood at carb watch the little 90* bent arm on the diaphragm pull down and open the choke plate flap a little. If it's working that is. No movement it's bad. About 12 bucks the last time, I had to buy one.. My 2cents
orich
Old Mar 15, 2014 | 07:14 PM
JohnnyLogic
I found the problem. I little to no spark and traced it back to bad breaker points. I decided to replace the points with a Crane XR-i as well as some new low resistance plug wires, and new coil. She fired right up with the new parts, runs great. Thanks again for all the suggestions.
Josh MUDDIN 4Life
Jan 17, 2011 01:02 PM
Triple_E_Farms
Jan 30, 2010 09:35 AM
AerostarDad
Aerostar
May 22, 2007 12:15 AM
1962_Fords_rule
Jan 12, 2005 08:57 PM
ford390gashog
Sep 14, 2004 11:28 AM
