1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
trying to figure out my fuel fill issues
Old 04-17-2014, 06:39 PM
FWD's Avatar
FWD
FWD is offline
Trailering
My problem ended up being the canister. I had the dealer replace it. It wasn't cheap but I was tired of high blood pressure while filling the truck. I figured this was the problem as the truck belonged to a farmer and it was on a lot of dirt roads.
Any way after I had the work done I stopped and had an uneventful fueling!
FWD
  #32
Old 04-17-2014, 07:13 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
Sorry I never reported back. The purge valve was not the solution. The lower line that runs in to it is though. There is a venting problem from the tank that disconnecting that line helps. The canister flows freely so that's not the issue so I'm guessing there is some sort of check valve in the tank or on that line that is bad.
The problem all started after I entered in a truck pulling even at a local fair. The truck wheel hopped a lot so maybe something came loose.
1965fairlane
18
01-31-2022 05:09 PM
turnrjr
08-11-2019 09:31 AM
Torsten.H
15
09-28-2016 12:09 AM
cookingguy
10-14-2014 08:56 PM
Quick Reply: trying to figure out my fuel fill issues
