2001 Ranger with 99 motor...
Old 03-02-2014, 01:44 PM
andrew'sRanger's Avatar
andrew'sRanger
andrew'sRanger is offline
Question 2001 Ranger with 99 motor...
okay so i have a 2001 Ford Ranger with a 99 motor in it. im throwing a #2 cylinder misfire. i have checked everything, from distributor, to the wire, to the plug to see if they were bad. i know it can also be a fuel injector to the valve seat on/in the head (worst case). im wondering if my re-machined heads from a 01 3.0 motor are compatible with the current 99 3.0 motor that's in currently in my ranger????? if anyone know please provide an answer!!
Old 03-02-2014, 02:44 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
As far as I know, the heads should be compatible. Here's one source: http://rogueperformance.com/vulcanFAQ.html
Old 03-03-2014, 03:04 PM
smalltrucker's Avatar
smalltrucker
smalltrucker is offline
I looked at car-part.com for comparble heads and shows a '99' will interchange all the way up to 2008
Dave
Old 03-08-2014, 02:26 PM
andrew'sRanger
Question #2 cylinder misfire 99 3.0 motor in a 2001 ranger
okay so this is weird! so over the past few days ive noticed when i fill my tank up the check engine light goes off and my truck runs smooth and doesn't miss a beat!!! when it get to below half a tank/ 1/4 of a tank the engine light comes on and it idles rough and runs well like its missing (#2 cylinder).. ive checked the spark plug, the wire, and im stumped!! i know that it could be a a lot of things causing this but why on earth does it quit when i have a full tank?
Rogue427
12-19-2016 04:35 PM
dirt_man
12-24-2015 04:41 PM
ValerieJT
05-13-2008 12:58 PM
LT99ranger
01-14-2005 01:48 PM
czcountryboy
12-27-2004 07:47 PM
Quick Reply: 2001 Ranger with 99 motor...
