I used the same plastic plugs to route the drains out the front, works good. Keep the hose long enough that it drains straight down and not on the body all the time.
The rollbak has no external locks to pick like the pace. You have to open the tail gate first, then the locks are manually retracted from under the cover. If you lock your tail gate, it is pretty damn tough to Jimmy it.
