front axle swap
Old Mar 2, 2014 | 09:34 AM
ifurlong's Avatar
ifurlong
front axle swap
just picked up a 75 F250 4X4, is there a dana 60 that fits in there with the narrow frame?
Old Mar 3, 2014 | 10:53 AM
chris989's Avatar
chris989
1977-79 had 31.5" width springs on center. Not sure what is was in 75.
Chris
Old Mar 3, 2014 | 03:27 PM
fordcrzymike's Avatar
fordcrzymike
I think there was an optional low pinion 60, not very desirable.
Old Mar 3, 2014 | 08:37 PM
PA74F250's Avatar
PA74F250
The front width is same as all 73-79 trucks. Get yourself a 78/79 high pinion D60 or HP D44. Even the 44 is much better than what you have. If you do the swap you'll have to do a little changing of master cyl and some other little stuff to make it work. Oh and might as well do the 78/79 power steering conversion.
I did the whole works with a D60 and it was expensive but worth it.
r2000f150
Oct 15, 2018 08:35 AM
1jeffm
Mar 5, 2015 11:00 AM
1977fordhighboy
Oct 21, 2011 08:08 PM
Oskar Pilot
Apr 18, 2007 07:30 PM
1ole4d
Jul 20, 2002 09:21 PM
