Swap engine to 460
Old Jul 1, 2003 | 07:37 AM
first time 4x4's Avatar
first time 4x4
Swap engine to 460
I am in the process of turning my truck into a dedicated mud truck. I want to run 38 or 40 inch tires and I know that my 5.0 won't have enough juice for the job. I came across a really clean 460 from a 1991 f350 only 54,000 mile and I bought it really cheap. Engine runs perfect. I got everything from the intake down to the motor mounts and all accassories and wiring. I need to know what type of tranny I need cause I'm pretty sure my mazda 5-speed won't bolt to it and will my transfer case (1356) be ok. Also will there be enough power from a stock 460 for a good mud truck or should I leave the 5.0 in and do some mods to the 460? ANy advice will be appreciated. Thanks in advance.
Old Jul 1, 2003 | 10:07 AM
Tectron1's Avatar
Tectron1
Swap engine to 460
In my opinion a 460 is the only way to go, I had a stock 460PI in my 76 and it had all of the power needed and then some to spin roosters on all 4, 38 inch gumbo mudders.
Old Jul 1, 2003 | 11:23 AM
c_rossman's Avatar
c_rossman
Swap engine to 460
The 1356 will be fine, I have that in my 93 with a 460. Find a ZF-5speed and you will be good to go. They are pricy 1000 bucks for a good used one.
Old Jul 2, 2003 | 08:24 AM
first time 4x4
Swap engine to 460
Is this going to be a pretty straight forward swap? Everything is in tact on the 460 and it probably should bolt right up with a new ZF tranny. What surprises will I run into? Any insight from someone who has done this is greatly appreciated.
