Power Steering Bracket Larger Picture
Old Mar 1, 2014 | 10:58 PM
fabieber's Avatar
fabieber
First post had a picture size that I couldn't even make out - hope this helps.
Old Mar 2, 2014 | 10:19 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Much better! I couldn't see anything on your first post. Really looks like it will do the job and the price is Right
Old Mar 2, 2014 | 07:51 PM
fabieber's Avatar
fabieber
As all of you veterans have talked about, "price is right" becomes very important and I find myself thinking that I want things to look good but I doubt anybody will approach me and want to look at my power steering pump brackets. If they do, I hope they won't mind my less than factory appearance.
Fred
Old Mar 2, 2014 | 07:57 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Nicely done
I'm all about "price is right" as I don't have much extra cash to toss at my truck. Besides, there is a certain satisfaction from doing it yourself.
Good job
Bobby
Old Mar 2, 2014 | 08:56 PM
fabieber's Avatar
fabieber
Thank you Bobby. I am compelled to post pics again when the engine is ready to go back in because the finished product on the brackets really turned out better than the rough cut ones shown.
I had never manufactured anything from metal and it was quite satisfying to have done it.
Now I am going to go to work on patch panels for the rear fenders where the running board attaches. I figure that my work will be hidden when the boards are back on so I won't have to be too finicky.
Old Mar 3, 2014 | 10:08 AM
AXracer's Avatar
AXracer
IMHO when you make the final version I think you will need to make it out of much more substantial material (Note the material used for typical generator or alternator brackets.) when the wheels are turned to the maximum the pump is putting out it's maximum pressure and will put a lot of strain on the belt torquing the pump. This in turn will cause the belt to slip or jump the pulleys. Sometimes manufacturers will use stamped 1/4" brackets but will stamp in stiffening ribs and/or turned edges.
Old Mar 3, 2014 | 10:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Welding on a piece of 1/2"-wide strap to create a flange on the brackets would stiffen it up nicely.
Old Mar 3, 2014 | 12:51 PM
AXracer's Avatar
AXracer
1/4 or 3/8 " square welded on top the edge would do the same as long as done carefully so as not to warp the bracket, but in conversations with the OP I didn't get the feeling he has welding equipment (note his statement that this was his first attempt at metal fabrication). Thicker material doesn't require welding, and a trip to the scrap yard can yield a bucketful of used bracketry to adapt and/or modify for next to nothing.
Old Mar 3, 2014 | 11:00 PM
fabieber's Avatar
fabieber
Ross and Ax -
When I tightened all bolts on the engine and where brackets connect to pump I could barely get any flex on the brackets with full arm strength. I do have a welder and could weld some strengthening brackets but don't quite understand where they should go.
Thanks for you interest guys....it is really helpful.
Fred
Old Mar 4, 2014 | 08:53 AM
AXracer's Avatar
AXracer
If you could get ANY flex by hand, the bracket will flex and possibly throw the belt in use, the belt will put a lot more force on it than you can by hand. What you want to do with stiffeners is to weld the stiffeners along the edge of the bracket to form it into a C channel or angle iron shape, either/and add finger like ribs to resist the bending force direction.
Old Mar 4, 2014 | 10:35 AM
AXracer's Avatar
AXracer
examples of added stiffening ribs:
be sure to check for and straighten any warpage after welding.
Old Mar 4, 2014 | 07:57 PM
bobbytnm's Avatar
bobbytnm
Another option would be to run a short brace from the bottom rear of the pump back to the engine block. A lot of factory type bracket set-ups utilize the rear lower bracketry.
Or...you might not need it at all, every situation is a bit different, only time will tell
Bobby
Old Mar 4, 2014 | 10:59 PM
fabieber's Avatar
fabieber
Thanks again AX and Bobby. On the larger picture there is a straight bracket that runs from the side of the pump to a bolt at the bottom of the engine under the fan. Before I added that there was definitely movement on the brackets...now not.
But, AX, I see where the strengthening of the brackets would be added help and I believe I can do that welding. I will check for warping when I am done.
Fred
Old Mar 5, 2014 | 05:03 PM
bobbytnm's Avatar
bobbytnm
Excellent,
A little welding, a little paint, and you're good to go.
On a side note....I was reminded that its time to replace my welding gloves. I did a bit of welding on my steering column brackets recently. Then (like everyone does after welding on something) I reached down to pick it up to have a look. Well, I got an instant reminder about the worn out spot on the index finger of the left hand glove. It sure didn't take me long to look at my weld.....
Bobby
Old Mar 6, 2014 | 09:01 AM
AXracer's Avatar
AXracer
Originally Posted by bobbytnm
Excellent,
Bobby
Was it on the other side of the room or on the floor at that point in the examination?
56 ford custom
22
Jul 28, 2013 07:36 AM
flip4eva83
Nov 14, 2011 10:38 AM
andrew1
Nov 14, 2010 04:47 PM
lbrauer
Mar 25, 2010 06:48 PM
