Coming up the mountains here in Ca last night. Snowing and slippery. Put truck in 4x4 light came in saying engaged. Driving very slowly and almost slid off road with two kids and wife in car. Then noticed that there was no front traction happening. Locked hubs manually and all was ok. I think this is a serious problem. If in auto and dash confirms 4x4 engaged then it should be. I am just very lucky to not have seriously hurt my family or someone else. Is this a recall on Fords part I truly think they need to be held accountable if so. Thanks in advance for any info.
Do they work now or still doing it?No recall I can find.Might be a problem with the vacuum lines to the hubs.This was a common problem on older 7.3s.But that was because the lines would start to degrade and get holes in them when trucks got older..The light may just be a dummy light meaning the 4x 4 switch was turned on but may not mean they are actually engaged.I changed mine over to warn manuals when I had my 7.3 .But the auto feature is nice since you dont need to get out of truck to engage them.As far as being a saftey issue though im not sure you have much of a case.Roads are slick and you need to drive accordingly.When I put in 4x4 i usually do it at a complete stop,I hear the clunk and can be fairly confident the hubs engaged.
I hate sound condescending, but this is very common issue that's relatively minor in the grand scheme of things. There is no sensor that exists in the hubs, and the truck has no way of knowing whether or not they are engaged. If I remember right the BCM controls the 4WD, and it functions by applying a vacuum to the hubs through solenoids in the engine compartment. It does this after it detects that the front driveline is spinning and locked in at the transfer case.
Sounds like you have an issue with either the vacuum lines to the hubs or the solenoid that operates them. In the meantime I'd suggest leaving your hubs locked manually if you feel this is that much of a safety issue.
The search feature is still working for everything but smart phones.
This has been discussed in great detail , with all of the information needed to make the proper repairs your self .
I lock them in all winter season when I need 4x4 to engage quickly and this also eliminates the loud bang when you are engaging 4x4 while in motion (the sound of the front end going from stationary to traveling speed).
Sometimes appropriate use of shift-on-the-fly 4x4 can be beneficial, for example if the vehicle is fishtailing on a highway that is glare ice, engaging 4x4 and very light acceleration will often straighten the vehicle out before the rear end passes you
It is the auto hub feature that runs on a vacuum system. IF the system is damaged or leaking it won't engage 4x4 but the electronics say it is. Or in cold weather I had the same problem thinking I was in 4x4 yet when stuck I noticed the front wheels were not engage. Turn the hubs to locked and by-pass the vacuum system will give you 100% confidence you are in 4x4. Don't leave the hubs in locked position all the time and you will get less wear and tear and better fuel economy. Just put in lock when you need 4x4 or if you want to turn the mechanical 4x4 front end for lubrication.
Mine have done the same thing... took it into dealer and it was repaired under warranty. It has nothing to do with the vacuum lines. Its an electrical issue. ( mine was at least ) I believe it was the 4wd actuator. Let me know if you have a problem and I'll see if I can look at the warranty slip to find a part number that they replaced.
Same with mine, it was an electrical issue, was nothing to do with vac lines or hubs. I had the same issue last winter driving home with my son and pregnant wife in a bad snow at night truck would not engage no matter what I did. After 6 times to the dealer they got permission from ford to remove some sort of relay or something and just wire it straight through. I have never had the problem since. I still have the paperwork on it I'll half to look at it again to see exactly what it was.
Mine was doing the same thing and after several trips to the dealer they have repaired the issue but I still have a very noticeable clunk when it engages my dealer says that's "normal" even though it did not make the noise in the first 60,000 miles I have owned the truck. FYI they replaced the 4x4 controller, the left front seals and hub after trying new lockouts to solve the issue.
Mine clunks as well.Not any more or any less noise then any of my previous trucks.
I work for the city I live in and frequently plow and salt this time of year , I drive a 2000 f350 4x4 gasser and sometimes the sylinoid freezes on the transfer case
yes I had the issue too which ended up being a slow vacuum leak. I physically got out and locked the hubs and everything worked great. I'm so glad Ford has this manual feature. Does GM and Ram offer the manual locking hubs? If not this would be a big factor for me on my next purchase.
I'm no expert, but I don't believe the other makes use hub disconnects at all. I did some quick searching around and couldn't find much information, so perhaps someone will prove me wrong.
