So heres the story. I have a 77 f250 4x4 with a 400m and manual transmission built up bored out bigger cam that I use as my pulling truck (the 300 ft kind). Last summer as I would go down the track it would sputter at around 5000 rpm but run great below that. In order to fix the problem I bought an entire msd ignition system (coil, wires, plugs, 6al box, distributor cap) thinking I didn't have enough spark. Well last week I finally finished it and much to my dismay now it idles fine but the second you hit around 2300 rpm it starts running horribly sputtering and dieing. I thought it was something with the vacuum advance so I bought an entire new distributor but that didn't help at all. So now im stuck. I have literally no idea what next. I appreciate you taking the time to read all this and if you have any suggestions or help to offer id gladly take it
With a hotter spark and more complete combustion, I think the engine is going lean. Did ya re-tune the carb to compensate? That's where I would start due to the new combination.
Takes 3 things to run right? Air, fuel, spark, sounds like a possible fuel delivery issue, since if sounds like you took care of any possible spark problem.
What carb you using, still have a mechanical fuel pump or electric? And if elec are you running a pressure regulator?
