56 f100 5.0 coyote swap project (help please)
Old 09-13-2014, 01:29 PM
walt460's Avatar
walt460
walt460 is offline
My local SCT dealer claims he can not by-pass the PATS feature on a 2011 F150 5.0L/6R80 controller. Has anyone actually had this done on a 2011-2014 F150 or 2011-2014 Mustang system?
Old 11-21-2014, 12:25 PM
cjvale's Avatar
cjvale
cjvale is offline
Is this dead? Does anyone know what happened to this build... I'm in a similar situation and could use some help...
Old 11-21-2014, 01:37 PM
walt460's Avatar
walt460
walt460 is offline
I don't know about the project above, but I do know that SCT can not turn off PATS in 2011-2014 F150s or Mustangs.
You need to keep PATS, so in an F150 that means keeping the donor truck's Key, PCM, and BCM. In a Mustang you will need the Cluster, Key and PCM all from same car. If the PATS items are not from the same vehicle, then you will need to visit local Ford dealer and have them Programmed to match whatever 80-bit PATS key you wish to use once you have your vehicle completed and ready to run.
Old 02-06-2015, 03:09 PM
stangetr's Avatar
stangetr
stangetr is offline
hello there, could we get an update please, many of us thought of this swap and the 6 speed auto sound great
Old 02-08-2015, 07:41 AM
craftsmangary's Avatar
craftsmangary
craftsmangary is offline
Subscribing, Any new news
Old 02-08-2015, 10:28 AM
walt460's Avatar
walt460
walt460 is offline
I do not see any new posts from Reneau87. Not sure if he has progressed or given up. I do know that 2012 Mustang 5.0L Coyote control system is very complex and that the PATS system is in the Cluster. You must have cluster plugged in, and use the original ignition key for the engine to fire. You must also connect the fuel pump circuit to let the PCM control the fuel pump or it will not fire. There are some other tricks too, but pretty basic stuff if you have all the factory wiring including the underhood fuel box.
Old 02-09-2015, 02:01 PM
wwagner479's Avatar
wwagner479
wwagner479 is offline
1948 Ford F1 Coyote Swap Update
My 48Ford F1 is in a SCT dealer shop in Memphis TN having a 2013 Coyote 5.0 truck engine with 6 speed automatic installed right now. I haven't heard of any problems yet as they say they have done this before. I'll update more when I hear the truck running or as I hear of problems. This is the first time for this shop to install the Coyote engine in a older truck but they have done several other swaps in older Mustangs before.
Old 02-09-2015, 02:19 PM
craftsmangary
That's good to hear, please keep us updated.
Old 02-10-2015, 08:30 AM
walt460's Avatar
walt460
walt460 is offline
Well this is going to be interesting, please do keep us posted as to this SCT dealer's ability to defeat PATS on a 2011-2014 5.0L/6R80 control system!
Old 02-10-2015, 09:16 AM
highdesert55's Avatar
highdesert55
highdesert55 is offline
Cant you just buy the control pack and harness from ford racing and it does away with all the problems? Other than the $1600 problem to buy it.
Old 02-10-2015, 10:44 AM
craftsmangary
The Ford kit is for a manual trans, it can't control the automatic transmission. Running a stand alone computer isn't the best way to go and I don't think anybody makes anything to control the 6R80.
Old 02-12-2015, 10:53 AM
wwagner479's Avatar
wwagner479
Latest Update
I just spoke with the shop that is working on my 48 F1 Coyote swap and they say that they will be turning the PATS system off. Once this is done there will be no need for the factory ignition switch and key or the body computer. They say they have done this before and have 2 different software systems that can defeat PATS. I don't know the name of the software company but will try to find out next week when the project leader returns. I'll try to update more as I find out more info.
  #28
Old 02-12-2015, 04:32 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
Cool, looking forward to the results
  #29
Old 02-12-2015, 09:41 PM
walt460's Avatar
walt460
walt460 is offline
Can not wait to find out which aftermarket software tuning software is capable of turning off PATS. I spoke with owner of SCT today (Chris) and he said that on 2011-2014 F150 and Mustang PCMs Ford put the PATS feature in an area of the code that can not be accessed. So SCT can not turn off PATS on these modules. I sure want to know which software company can do it!
  #30
Old 02-22-2015, 12:38 PM
JM10's Avatar
JM10
JM10 is offline
Since I wanted power steering for the truck, I have already purchased a kit including the power steering pump and mounting bracket from Sean Hyland Motorsports in Canada for a little over $600.
Did you keep the stock AC and Alternator from the donor truck?
I'm on the same boat building a f100 1956 with a complete coyote engine from a donor mustang (6R80). I want to save some $$ by keeping the stock accessories.
JM
Quick Reply: 56 f100 5.0 coyote swap project (help please)
