Need Help
Old Mar 2, 2014 | 01:50 PM
Matt Rucks's Avatar
Matt Rucks
Ok I'm new to 6.0, we're is the icp sensor at?
Old Mar 2, 2014 | 01:51 PM
cheezit's Avatar
cheezit
Liver is tasty
Old Mar 2, 2014 | 01:58 PM
Matt Rucks's Avatar
Matt Rucks
New to th 6.0 we're is the icp sensor at?
Old Mar 2, 2014 | 02:00 PM
npccpartsman's Avatar
npccpartsman
passenger side valve cover at the front.
Old Mar 2, 2014 | 02:22 PM
BLADE35's Avatar
BLADE35
Originally Posted by cheezit
Unplug icp and see if it will start. If so plug it back in then unplug #8 injector and see what happens.
My guess is a shorted spool valve.
Tryy this one Bud^^
Old Mar 2, 2014 | 02:33 PM
9228.bobcat's Avatar
9228.bobcat
Liver is tasty
Lol. Dont forget the onions.
Old Mar 2, 2014 | 02:46 PM
Matt Rucks's Avatar
Matt Rucks
Nothing
Wiggled the ICP wire and nothing, wiggled every wire nothing.
Old Mar 2, 2014 | 02:49 PM
04badford's Avatar
04badford
Did you unhook the ICP connection? what was ICPV values?
Old Mar 2, 2014 | 03:21 PM
Matt Rucks's Avatar
Matt Rucks
How do I check ICPV values?
Old Mar 2, 2014 | 03:42 PM
04badford's Avatar
04badford
Via Scan Gauge
ICPV
txd- 07E02216AD rxf- 0462451606AD rxd- 3010 mth- 004827100000
Old Mar 2, 2014 | 03:50 PM
04badford's Avatar
04badford
You need to take these Values at
koeo ( key on Engine off )
low ( just Idle)
high (2500 )
trying to drive the truck and take values are danger, besides the values takin like this are Ford specific
Old Mar 2, 2014 | 03:52 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Liver is tasty
Mr. Chopped, your table is ready .
Old Mar 2, 2014 | 04:05 PM
  #28
Matt Rucks's Avatar
Matt Rucks
icpv
Low= .84
2500= 1.96
key off =.23
Old Mar 2, 2014 | 04:06 PM
  #29
cheezit's Avatar
cheezit
My advise will only lead you to your concern if the truck wont resart. If you have a bad injector coil unpluging the icp sensor on the passanger valve cover should stop the back feeding of voltage to the ficm that Is shutting your truck down. If it starts you have narrowed it down to either a biased icp or bad injector. From there you will need to varify icpv then if its good move on to disconnecting one injector at a time.
If the concern is pretty easy to duplicate you may just wish to bypass the prior and just unplug injectors one at a time and drive it, imo suggest starting with #8 because that is the one that set a dtc.
Old Mar 2, 2014 | 04:11 PM
  #30
cheezit's Avatar
cheezit
Matt,
ICp koeo .23 is good
.85 at idle is good.
But if you are checking while its running it will more then likly be good. You need to get info when it wont start.
For your truck to start you need icp to be greater then 500 or .85v
