Speaker hole patch panel (Ver. 1.0)
Old Feb 27, 2014 | 12:55 PM
reamer's Avatar
reamer
Well here it is, something Gary and I (and many others) were discussing about what to do with the speaker section falling apart.
This "cubby" I designed is made so the bottom of the panel is horizontal when installed in the dash. Looks like there is enough room even with the steel speaker mount plate under the dash. Not sure till I find a dash "bad enough" to cut up with out feeling guilty about it.
painted red just to contrast it.
The deep end is the front, the shallow end goes towards the windshield
Sitting on "good dashes" Just can't find a bad one!
What do you think?
Old Feb 27, 2014 | 03:06 PM
RL250's Avatar
RL250
You can have mine. It looks like lizard skin. I snagged a spare from the junkyard to repaint.
Old Feb 27, 2014 | 06:29 PM
reamer's Avatar
reamer
I'll PM you with my address.
All I need is the center section, say 2" to the right and left of the windshield screw holes. So that would be about an 18 inches of the center section.
Old Feb 27, 2014 | 06:35 PM
Gary Lewis's Avatar
Gary Lewis
Interesting. Not sure what I expected, but I think it is bigger than expected. Might be very handy to put the cell phone in or other such "accessories".
How do you hold it in?
Old Feb 27, 2014 | 06:48 PM
reamer's Avatar
reamer
Don't know till I cut up a dash pad. Got Ideas...no dash to try them on.
What were you thinking of? Love to get some input.. think this will fly?
The cubbie is as big as the speaker hole area.
Old Feb 27, 2014 | 09:37 PM
tempest411's Avatar
tempest411
I'm a bit confused. Do you intend to cut out a big square from the dash pad and have that tray mounted from underneath? I would think just picking up a set of the optional door pockets would be a more elegant solution to increasing the storage for small items. From the title I was thinking you were going to come up with a way to repair the dash pad so as to make it appear new again.
Old Feb 27, 2014 | 10:24 PM
RL250's Avatar
RL250
Reamer- check your inbox. I think your mod might be useful. Especially if you are like me and plug your phone into your stereo for music. I was looking at converting the ashtray into a phone holder.
Old Feb 28, 2014 | 07:01 AM
reamer's Avatar
reamer
It will install from the top, where the EPDM edge will sit on top. secured from the underside. you can paint to match.
Old Feb 28, 2014 | 07:36 AM
1986F150six's Avatar
1986F150six
reamer,
Your missing donor dash pad has been located! Look at the attached link and see what Cienega32 found under a protective [cloaking?] cover!
https://www.ford-trucks.com/forums/1...today-813.html
Old Feb 28, 2014 | 07:44 AM
reamer's Avatar
reamer
WOW! and we are complaining with some holes!
Old Feb 28, 2014 | 08:55 AM
RL250's Avatar
RL250
Originally Posted by 1986F150six
reamer, Your missing donor dash pad has been located! Look at the attached link and see what Cienega32 found under a protective [cloaking?] cover! https://www.ford-trucks.com/forums/1...today-813.html
At least the one in my truck has part of the speaker grill left (1/2-1/4 of it)
Old Mar 1, 2014 | 10:13 PM
Brad from Oz's Avatar
Brad from Oz
How about something like this?
https://www.whitworths.com.au/main_i...AbsolutePage=1
Old Mar 2, 2014 | 07:04 AM
Gary Lewis's Avatar
Gary Lewis
Interesting. I'd always wondered what happened to them. After the fasteners and associated spanners didn't sell they moved on to marine equipment.
Old Mar 2, 2014 | 08:01 AM
reamer's Avatar
reamer
too deep, hits the brace
Old Mar 2, 2014 | 07:31 PM
Brad from Oz
Yeah I thought it might, but it would be easy to cut a wedge out of the tub and plastic weld it back together. Or heat it and mould it around the brace.
Paint it with SEM to match the dash - noice
girlwithatruck
88
Jan 28, 2024 11:32 AM
girlwithatruck
'80-'86 HOWTO's
77
Dec 3, 2018 08:57 PM
corppe
Jul 8, 2018 09:28 AM
RIPbiker13
32
Jul 2, 2018 03:38 PM
Boz86
Mar 30, 2010 05:55 PM
