Timbren
Old Feb 26, 2014 | 05:59 PM
ddbck's Avatar
ddbck
Timbren
Got mine today. Driveway still to snowy to put them on. will post pics. Any experience with these rubbers?
Old Feb 28, 2014 | 02:54 AM
PrinceValium's Avatar
PrinceValium
I looked at them as an option for towing...however the reviews I read said they can be harsh when not loaded and you hit a good bump or pothole.
Old Feb 28, 2014 | 06:42 AM
meborder's Avatar
meborder
you might try sending a PM to user Chris Anchor,
he had (or still has) timbrens on his truck, and that man knows how to use a truck.
https://www.ford-trucks.com/forums/1...l#post12586043
https://www.ford-trucks.com/forums/1...l#post10789353
he's the only one i know using them.
Old Feb 28, 2014 | 09:16 AM
fish98f250's Avatar
fish98f250
I have timbrens on my 2012 mainly for when I tow a travel trailer. I have a weight distributing hitch but did not like how soft the rear end was. I found the truck to feel more stable towing with them than without and it is nice to not have as much squat moving it around short distances when the WDH is not hooked up. They do make the ride stiffer when you are on rough roads but I haven't found it to be an issue.
The one real negative I have found is that when loaded up enough for them to just start engaging you can get a bouncier ride on the highway. I noticed this on a family road trip last year but only with certain highway conditions.
If I were looking now I would take a close look at the Torklift StableLoads as an alternative since you can disable them completely at will. I wasn't aware they existed when I installed the Timbrens.
Old Feb 28, 2014 | 10:10 AM
Champ198's Avatar
Champ198
I used Timbrens on my F250. Timbren can help you with selecting a rubber bumper that works for you (even if your model calls for a certain rubber mount). The key is getting the correct frame mount, then you can customize the height/size of the rubber bumper. The Timbren listed for my 250 didn't provide enough gap for normal ride (because I had a 5th wheel hitch that weighed the bed down) so they sent me a slightly shorter and smaller diameter rubber mount and it provided the correct amount of support and ride comfort. I'd use them again.
Old Feb 28, 2014 | 11:04 AM
fish98f250's Avatar
fish98f250
Champ has a good point about selecting the right bumper. I have read nothing but good things about the customer service from Timbren.
razehm
6.7L Power Stroke Diesel
22
Jun 25, 2017 04:35 PM
PrinceValium
2009 - 2014 F150
May 16, 2014 04:03 PM
hcaudell
2009 - 2014 F150
Sep 12, 2013 09:25 AM
Tom
Apr 14, 2013 10:57 PM
shortboxedf150
All Things Towing
Apr 10, 2005 09:43 PM
