Intercooler Test
Old Feb 26, 2014 | 01:59 PM
richdawg's Avatar
richdawg
Intercooler Test
I have a 6.0 cooler that i am planning to install. I would like to know how to pressure test for air leaks before i install it, any info on a good process for testing would be appreciated. I tried my own method of plugging the 3 in. inlet and outlet with a plumbing type plug. Well lets just say i got a little excited when one of the plugs blew off with a bang, so it didn't take me long to figure this was not a very safe way to do it
Old Feb 26, 2014 | 11:11 PM
oldbird1965's Avatar
oldbird1965
Block one end and use one of these on the other end. Put 20 psi in there and spray with soapy water. No bubbles, no leaks.
Old Feb 27, 2014 | 07:08 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
You've done this more than once
Old Feb 27, 2014 | 09:12 AM
oldbird1965
Just a couple times, LOL
Old Feb 27, 2014 | 09:37 AM
MOOSE_MACHINE
What is a reasonable price for a used intercooler. I found one local to me and the guy says make an offer
Old Feb 27, 2014 | 10:19 AM
oldbird1965
$100......
Old Feb 27, 2014 | 10:30 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Originally Posted by oldbird1965
$100......
Yes and no more than $150.00.
Rich, I went to a radiator shop and let them to test my IC.
Old Feb 27, 2014 | 11:16 AM
MOOSE_MACHINE
Awesome. I'll let the guy know. It's one out of a 06 6.0. For now I don't really need one but if I come across a good deal I may scoop it up
Old Mar 1, 2014 | 03:56 AM
richdawg's Avatar
richdawg
This is the plug i used, it worked just fine
This is the one i was having trouble with blowing off. It's kinda similar to yours, maybe i should get a white one. I walked away after it blew off a couple of times.
I will get back to it in a few days. sorry about the large pics
Glenn your cheating thow, i think your cooler is not a 6.0
Old Mar 1, 2014 | 08:28 AM
oldbird1965
Mine is a SD IC, how is that cheating? LOL
Old Mar 1, 2014 | 08:33 AM
Diesel_Brad's Avatar
Diesel_Brad
Just don't put anymore than 20psi in and make sure the clamps are tight
Old Mar 2, 2014 | 12:35 PM
rodneywar's Avatar
rodneywar
just a fair warning the 6.0 coolers arent that great as everybody says they are they are fine for stock to mild 7.3s but once you go big power you would want a aluminum endtanked ones i have seen a lot of 6.0 ic failed on stock 6.0 trucks oil is a factor as well but the way they are built with the ends crimped on leave a lot to be desired
Old Mar 2, 2014 | 12:36 PM
rodneywar's Avatar
rodneywar
and brad is right no more than 20 psi and stay clear of the ic s they can blow with force
Old Mar 2, 2014 | 08:07 PM
oldbird1965
Sounds like there is a echo in here!
Old Mar 3, 2014 | 01:50 AM
richdawg's Avatar
richdawg
Well that sounds easy enough.
I think thats a good idea Jose
I think mine came out of a 2005, i thought it was out of a Super Duty ?
I also thought you had some kind of after market cooler. does yours have aluminum or plastic like mine.
Thanks Brad, thats what i was trying to do. I think i was lucky really could have got hurt when that thing blew.
Ronnie, Thanks thats good info, i don't think i will build any more power after the cooler, just need to get a real chip. I'll try to make this plastic cooler work but if i have trouble with the boots blowing off i will start looking for another one. I'm not sure what you mean by "oil is a factor as well" can you or some on comment one that so i can better understand.
