Dieselsite fuel filter
IF it (the stock DFCM) deosn't work properly then get it gone!
Just my HO, for those that have it all the power to you, if it gives you peace of mind all the better. Fuel can't be tooooo clean
Good luck with your install seabee
I'm not one of them, of course.
I guess that's the bottom line. Piece of mind. Especially when I'm a thousand miles from home with that 35 foot 5th wheel coming along behind and I find myself having to get fuel from something other then a good high volume station. If I start seeing a lot (or maybe even any) water in the Dieselsite filter I have the option to stop, get the truck towed in and the fuel tanks checked and drained. Might even call my insurance company and see if they would pay for that in order to avoid a potential catastrophic failure.
Additionally, keeping an eye on water in the filters between fill-ups makes it easier to identify where the water came from. Thousands of miles with no water then suddenly I see water a few miles after filling up at Bubba's Pump n' Go in Nowhere USA gives the insurance company something to sink their teeth into.
Having the extra layer of protection and the ability to check it at a glance is worth twice the price to me!
bruce....
With the dieselsite filter set up you have the fuel run through two (2 micron) filters, and 2 extra chances of filtering out water before even hitting the factory DFCM.
It is a very low chance already if you are going to get contaminated fuel, but for myself with my tax return I felt getting it would help out in the short comings of the factory set up.
GM is have the same issues but at a smaller rate, and looking at the GM board they are surmising that it has to do with the better factory fuel filter set up compared to the Ford set up.
I have a diesel mechanic friend that will pull my fuel pressure regulator and inspect it in August(1 year mark for my truck) for any corrosion. I will report back with pics at that time.
If corrosion is discovered, then what should I do? My first response is trade it in on something else, but then the poor next owner will eventually get screwed. It will be a decision that is both a financial one and a moral/ethical one at the same time.
Dang I'm ranting again.
and hollowed out DPF/SCR from a donor vehicle
I wonder if Ford's filters pas SAE J1488 as sited in the video below.
After getting everything set up for the install (tools, light, creeper, etc) and removing the nuts from the frame rail/DFCM, I put the filter/separator in place and started to re-install the nuts (even had Locktight on the threads). It was then I noticed that the parking brake cable was really close to the top of the filter housing. Upon closer inspection (before tightening the nuts), I found that if I kept going, the parking brake cable would actually be contacting the top of the housing and putting pressure on the entire assembly. Needless to say, I took it back off and it is now back in my garage awaiting "Plan B". I think a half inch drop would do well. A quarter inch would suffice, but I prefer a little margin for slack in the cable when released.
I called Dieselsite, but it was after hours, so I left them a message. Hopefully, they will call me back tomorrow and provide a fix. Obviously, I could drill new holes and lower the assembly myself, and that may be what ends up happening, but I shouldn't have to. If that ends up being the case, so much for a 15 minute install. It's a shame too, because after crawling under the truck and looking around, it was going to be extremely easy to do. I didn't even need a screwdriver to pop the quick connect fittings loose from the DFCM. (I popped them loose, but did NOT take them off.)
This sux. I was psyched to finally have a small window of opportunity to get this done.
If you have a truck with the same config as my sig truck, you may want to wait before ordering on of these.
Sure.....you can give the extra one to a fellow Sailor..........
....I have to say, the crew at Dieselsite are first rate with regards to customer service. My call was returned within 30 minutes of placing it - even though it was after hours. After an initial discussion of my issue with a possible solution offered, I emailed them pics of what I was experiencing. I tried their possible solution and it didn't provide the clearance that I needed. I ended up oblonging the holes in their mounting bracket, on the housing side, to allow it to drop. I only needed a 1/4", but wound up with a 1/2" when I was finished. If I have another window of opportunity tomorrow, I will once again attempt to get it installed.
After speaking with their tech, it appears as though he is using my pics to do a small modification for future shipments, so that this will no longer be a possible issue. I have sent him pics of the results of the mods - uninstalled - with recommendations, and will provide pics of the result once completed and functioning.
Roy, PM me with shipping details. I'll have one sent to you. Thank you for your service sir. I'm still trying to catch up on the "One page.." Much respect for you.
Roy, I have DieselSite's equipment on my 2012 and it bolted right up. If it bolts to a 12' then you should be fine on an 11'. This is just me speculating.
