Differential Seal
Old Feb 26, 2014 | 10:47 AM
vmunoz_elec's Avatar
vmunoz_elec
Differential Seal
03 exp xlt 4.6 Any pic's and tips on changing out the seal to differential . I have a leak where the drive shaft marries into the diff. Saw on site where they indicate that u have to re-tighten nut to a specific number. Thanks!
Old Feb 26, 2014 | 12:15 PM
alloro's Avatar
alloro
Mark the nut and pinion shaft with a punch, back off the nut and count the turns. Remove the flange, replace the seal, and then reinstall the flange. Now install the nut the exact number of turns it took to remove it, right up until the marks you made line up. You're done.
Old Feb 27, 2014 | 11:24 AM
vmunoz_elec
Thanks Again! Do you know much about a/c? I ve replaced the clutch hub, pulley and it still is making noise when engaged guessing compressor bearing ?
Old Feb 27, 2014 | 01:19 PM
alloro's Avatar
alloro
If the noise is coming from the compressor area, then yes it sounds like a bearing in the compressor, not the bearing for the clutch.
Old Feb 27, 2014 | 07:34 PM
vmunoz_elec
Yes noise is diffiently coming from this area I've replaced two of the idler pulleys only ones left would be the tension idler pulley and the one right above it.I think that the latter one is to far away noise is closer to bottom.With 180k maybe it might be that tension pulley under load too much for the bearings. If compressor bearing would it be cheaper to do bearing vs replace the hole smash (understanding a full re-charge is needed in both cases) .Man the wealth of knowledge and experience on the site priceless.
Old Feb 28, 2014 | 12:47 AM
alloro's Avatar
alloro
Get a 3'x7/16" wooden dowel from your local hardware store. With the engine running, touch one end of the dowel at the base (non-moving) area of any place with a bearing, and hold your ear against the other end of the dowel. (Naturally don't stick it in your ear.) Any noise a bearing generates will travel up the dowel to your ear. This makes it very easy to hear a noisy bearing.
Old Feb 28, 2014 | 08:38 AM
2trux's Avatar
2trux
If it only makes noise when compressor is engaged I would say it needs a new compressor.
Oddly enough when the front seal of my 97 started leaking I found it cost the same for me to replace the compressor as have a shop replace the seal. My guess is replacing a bearing inside the compressor will not make sense.
To be earth friendly first visit an A/C shop to have your freon sucked out so it can be recycled.
Old Feb 28, 2014 | 10:17 AM
vmunoz_elec
Thanks again to all.I'll check into that McGyver stethoscope alloro.Rock auto has a compressor and component kit which includes o-rings receiver dryer,and expansion valve.How many of u feel this is necessary to change when replacing just compressor/bearing.(its about 40 o-rings in kit!)
Old Mar 5, 2014 | 08:04 PM
pinellas50's Avatar
pinellas50
Alloro is spot on. You have to unbolt the drive shaft from the pinion before doing this of course. Instead of using a punch I used paint to put line up marks on the parts. A punch is probably smarter because paint can wipe off.
When putting the flange back on the pinion I highly recommend you coat the splines of the pinion with RTV Gray. The gray part of that is important because it is made for high torque applications. When I first replaced mine I didn't put anything on the splines and gear oil started creeping up the splines and leaking out during operation. A mechanic friend of mine is the one who told me about the RTV gray and it hasn't leaked a drop since I pulled everything back apart and coated the splines with the stuff.
DBGrif91
Dec 2, 2013 05:28 PM
cajunsuperduty
Aug 19, 2011 08:50 AM
exploder sport
Mar 2, 2010 03:21 PM
wlihntr
Mar 21, 2005 11:06 AM
ssap108
May 6, 2004 10:41 PM
