quick question on install.
Old Feb 25, 2014 | 07:01 PM
UcaN's Avatar
UcaN
Hello guys.
I am just about ready to drop in a replacement engine on my truck. When I removed my damaged engine I took off the turbo to make it easy pulling out the engine.
It is so much easier setting up the bellowed pipes and turbo while I have the engine out of the truck.
My question is:
Will the engine go in with the turbo installed or will I have a clearance issues on the firewall.
Thanks..
Old Feb 25, 2014 | 07:04 PM
JOHN2001's Avatar
JOHN2001
I haven't done it personally but in the few threads I've read about it over the years it's best to pull the turbo. Otherwise you won't be able to push it back and snake it in there. It would be too low
Old Feb 25, 2014 | 07:14 PM
Pikachu's Avatar
Pikachu
When we pulled my engine the turbo was off, but even with the lower early 99 turbo, I'm pretty sure the only way I could get it back in with the turbo on it would be with an adjustable spreader bar on the hoist, and/or by unbolting the cab and jacking it up.
Old Feb 25, 2014 | 07:17 PM
UcaN's Avatar
UcaN
Hhhmmmm. I thought so. It's just so much nicer setting the turbo up outside.
Off comes the turbo...!!! Jajaja.. thanks
Old Feb 25, 2014 | 08:30 PM
snakedoc's Avatar
snakedoc
no way to put in it with the turbo on it not room to raise the engine over the cross member.
trevorrules
Jun 21, 2015 04:16 PM
Muddy 13
Jun 20, 2011 06:29 AM
clunker86
4 Cylinder Engines
Feb 25, 2010 05:33 PM
