Missouri Chapter Join Chapter , Leader:77&79F250
My project
Old Feb 24, 2014 | 08:46 PM
dbeers02's Avatar
dbeers02
My project
Well here is the truck. She is running good so far. Had a few little irritating things I have had to fix but I guess that is expected for a truck that sat for 10 years without being started or even covered up.
Now I am making the list of things I want to replace or change.
4-6 in lift
Possibly a SAS conversion
Roll bar with KC lights
push bar
new interior
good dashpad
36 inch tires
fresh paint
etc.etc.etc
Old Feb 24, 2014 | 09:05 PM
earthquake68's Avatar
earthquake68
Once you start, it just keeps on going and going and going. .....good luck and keep us posted. It looks like a decent truck from here.
Old Feb 24, 2014 | 10:41 PM
Trombogon's Avatar
Trombogon
Looks like a beast bud, I'm gonna guess and say it has a 460 with a C6?
Old Feb 25, 2014 | 09:13 AM
dbeers02's Avatar
dbeers02
Yes. I believe it actually has a rebuilt 1973 460 in it. I looked at the casting codes and the date codes on the intake, block to determine that. D3 part number and 73 year date code. The The paint on the engine is pretty good and is the older style blue. It runs pretty strong. Also the tranny has been into also. There is silicone around the tranny pan and it definately has a shift kit in it. Hits pretty good from 1-2 and 2-3 shifts.
Old Feb 25, 2014 | 11:16 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Are you driving it to the G2G in April? Nothing like a 1 ton 4 door....
Old Feb 26, 2014 | 09:30 AM
dbeers02's Avatar
dbeers02
Rich, I dont know if I will be able to get away or not. I will see what I can do.
And so it begins... I just ordered the Rough Country 4 inch lift for this truck. Hoping to get 35 or 36 inch tires under it. Price wasnt too bad. Less that I expected. After some "negotiation" I picked it up for $529 shipped to my door. Springs, shocks, brackets, blocks for the rear, and hardware. I think I will try to get it installed this week. Then off to some tire shopping. I wonder if the hummer M/T military tires will fit. I did some measuring and if the kit is a true 4 inch, looks like they may fit and I believe my springs do have some sag in them from age.
I want to build this truck into a good hunting/mudding/ SHTF truck that will carry 6 people comfortably and go about anywhere( at least anywhere that doesnt need a tight turn) this thing takes a football field to turn around.
Old Feb 26, 2014 | 09:44 AM
77&79F250's Avatar
77&79F250
If you want to run Military hummer tires you will need 16.5 rims... they come in 36" and 37" tall and are 12.50 wide.
No the bead lock run flat rims will not fit the front end (too deep set, like 7") unless you get them recentered.
Not that I support un safe acts like making a device to hold your e-brake release handle out (that keeps your e brake from staying on) and getting good at e-brake U turns....then you will not need a football field.
indianabackroad
Mar 22, 2012 07:24 PM
Prozon
Offroad & 4x4
109
Sep 30, 2009 11:51 AM
DeckedoutF150
Ohio Chapter
Oct 6, 2005 08:29 PM
superdutymj
Aug 17, 2004 10:16 PM
Obtuse1
Mar 15, 2003 11:28 PM
