AC Pressure's
Old Jun 30, 2003 | 07:11 PM
cjkozik's Avatar
cjkozik
AC Pressure's
I have a 93 Ford F250 Diesel which I've recently had some A/C work done on. The mechanic converted my system to R134a and ended up with the following pressures High 280 Low 54. The A/C will only cool down to around 66 degrees at idle with the A/C set on Max. The Temp average is around 92-98 degrees with high humidty here in Texas. What will it take to get these pressure down to a normal level and obtain some better performance from the A/C. Or is this the best that the system will perform. The Mechanic told me that he could probably get the low pressure down if I purchased a new compressor. DO I NEED A NEW COMPRESSOR OR NOT????????? Please help!!!!!!!!!
Old Jun 30, 2003 | 07:59 PM
LxMan1's Avatar
LxMan1
AC Pressure's
54 is a bit high for 134A 45 max is recommended. If the system is in good shape, it should get down in the 40 degree range. My 88 Mustang will blow about 38 degrees on max. I would have them check the orfice tube and check for debris. You could have a compressor on the way out. I would also make sure that they vacuumed out the system good to make sure that there was no moisture in the system.
Jimmy
Old Jun 30, 2003 | 08:13 PM
cjkozik's Avatar
cjkozik
AC Pressure's
I forgot to add that the mechanic did replace the orfice with some sort of variable orfice and he claims that he pulled a vaccum on the system.
Old Jun 30, 2003 | 08:16 PM
LxMan1's Avatar
LxMan1
AC Pressure's
I wonder if the one that he removed was contaminated with anything?
Old Jun 30, 2003 | 08:22 PM
cjkozik's Avatar
cjkozik
AC Pressure's
He did say thay there was some debris in the old one.
Old Jun 30, 2003 | 08:30 PM
LxMan1's Avatar
LxMan1
AC Pressure's
It may be in need of a compressor soon. Our C&^#y Astro van is in the same boat. I have cleaned/changed the orfice tube twice and it keeps getting metal shavings in it. The compressor is coming apart on the inside. It doesn't make any unusual noises, but it wint be long. Even when low on freon, it won't drop below 50psi on the lowside. The compressor is not moving the freon like it should. My guess is thst a new compressor is needed.
Jimmy
Old Jul 2, 2003 | 11:37 PM
greg_23805's Avatar
greg_23805
AC Pressure's
Reasons for high pressures:
1. dirty condensor coil
2. orifice too large thereby suction pressure and consequently high pressure gets too high
3. overcharged
I'd check all of the above or have them checked by a different mechanic before changing the compressor. Don't throw parts at it, have someone eliminate the problem by proper diagnosis.
Old Jul 3, 2003 | 09:34 AM
steve83's Avatar
steve83
AC Pressure's
2. orifice too SMALL. If the orifice was the same size as the hose (GIANT), the refrigerant would flow freely thru the system and almost NO pressure would build up - it would stay close to what it is with the system off. But if the orifice gets blocked (too small), then the compressor will pump ALL the refrigerant to the high side, and it can never flow back to the low side, so the high side pressure would go SUPER high.
I totally agree about diagnosis before buying parts.
Old Jul 4, 2003 | 11:39 AM
cjkozik's Avatar
cjkozik
AC Pressure's
Would this also make the low sided pressure high as well.
Old Jul 4, 2003 | 10:41 PM
Dartagnan00001's Avatar
Dartagnan00001
AC Pressure's
My book(s) says High side high and low side high equals air left in system.
Dart
Old Jul 4, 2003 | 11:14 PM
greg_23805's Avatar
greg_23805
AC Pressure's
cj, where do you live? I live about 60 miles west of houston. If you are around Houston, I can help you out but you would have to bring the vehicle to my house. If you have air in the system or it is overcharged, your high and low pressure readings will be higher then normal. You are going to need to take the vehicle back to a shop to get this fixed unless you know someone with the tools. The first thing to try is to remove refrigerant until the clutch starts cycling with the engine rpm up around 1500 and normal a/c, high fan. Then slowly add until the compressor quits cycling. If the air is much cooler, it was overcharged. If the air still isn't cooler, you have air in the system.
Old Jul 5, 2003 | 11:01 AM
cjkozik's Avatar
cjkozik
AC Pressure's
Greg I live in Needville Texas its about 40 miles Southwest Of Houston. If you are indeed interested about helping me out. Please Reply back to this message and we can go from there.
Old Jul 5, 2003 | 09:25 PM
greg_23805's Avatar
greg_23805
AC Pressure's
Let's preliminarily shoot for this coming Sunday. Send me an email at greg_23805(No Email Addresses In Posts!) so we can exchange phone numbers and stuff.
RA5226
May 21, 2014 10:41 PM
lisagk
Jun 26, 2013 07:59 AM
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
Imflamecrazy
Aug 27, 2009 08:48 PM
greg_23805
Sep 22, 2002 07:34 AM
