stupid distributor is stuck...
Old Feb 23, 2014 | 09:40 PM
BRay09's Avatar
BRay09
Trying to figure out a crank no start on this 89 f250 with the glorious 5.8. I've looked at spark, sparks good. Fuel pressure is at 38-40 psi. Plugs, wires, cap, rotor have all been changed.
Seems like it wants to fire up after the first couple revolutions, then it just cranks. If you use either, it'll fire up and die and you can't keep it running with either. So I was thinking about changing my ignition module. Low and behold... it's stuck. Now I got it soaking with PB blaster and have tapped around the base with a hammer. I can't get it to turn. I was wondering if any of you have ran into this issue and what you did to solve it...
Old Feb 23, 2014 | 09:46 PM
danr1's Avatar
danr1
Yea I did I used a crescent wrench on the large wrench boss built into the distributor body itself (at least they did that) to break it free, it took some time to do kept soaking it down taping it back and fro now and then until it came free. I did not want to add to the problem by snapping it off, I just wanted to adjust the timing but was not happy to find it froze in place no.
Old Feb 24, 2014 | 04:49 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Your truck was running and now it won't.
It has good spark and fuel pressure and it will fire on ether.
Have you checked for injector pulse with a noid light?
Sounds more like a computer issue than timing.
As for your distributor, keep soaking, tapping etc...
Obviously it hasn't moved, and if you have spark I doubt it is at fault.
Old Feb 24, 2014 | 05:35 AM
BRay09's Avatar
BRay09
I checked cylinders 4-8 with a noid light and they were firing. I actually plugged in another computer to rule that out and it still just cranks.
I have pulled the plugs after cranking awhile. They were black, but were not wet.
Old Feb 24, 2014 | 06:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If they're not wet after that kind of cranking, there's no fuel getting into the cylinders.
IDK
Old Feb 24, 2014 | 10:00 AM
BRay09's Avatar
BRay09
If the injectors are getting a signal to fire, then why are they not letting fuel into the cylinders? could I have lost a ground somewhere?
Redneckfordf2502002
Mar 6, 2013 11:19 PM
rockcrusher1985
Feb 2, 2013 03:26 PM
calguy
21
Dec 6, 2011 07:19 PM
Offroadin
Bronco II
Jul 7, 2007 10:53 AM
BII Plow Truck
Bronco II
13
Sep 14, 2006 10:30 PM
