Transmission Question
Old Feb 23, 2014 | 09:17 PM
darren_palms's Avatar
darren_palms
I just bought 1979 3/4 4x4 automatic so I can put my 1978 camper special body, engine, and transmission on it. I was wondering if the transmissions were the same on the 4x4 and the camper special (400 in the 4x4 and 460 in the camper special)?
Old Feb 23, 2014 | 09:23 PM
jgavac's Avatar
jgavac
They should both be C6
If the 78 CS is 2wd, there is a big difference between them.
Now if you're referring to the bolt pattern, it's the same.
-Jameson
Old Feb 23, 2014 | 09:27 PM
darren_palms
-Jameson
Yes the camper special is a 2wd...is the transmission a different length?
Old Feb 23, 2014 | 10:06 PM
jgavac's Avatar
jgavac
Different tailshaft housings. The 4wd has a transfer case hanging off the back, the 2wd does not.
Old Feb 23, 2014 | 10:23 PM
darren_palms
I figured the tailshaft would be different but could you switch tailshafts? Both trannys are good but the camper special one is better.
Old Feb 24, 2014 | 06:03 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Non-divorced attaches directly to the transmission. A flange on the trans tailshaft housing mates up with the mounting surface on the t.case and the trans tailshaft is splined into the t.case input gear.
Yes you can switch tail-shafts, if you know how to disassemble a transmission completely.
Old Feb 24, 2014 | 09:12 AM
trozei's Avatar
trozei
Ohh, I'd forgotten that the '78 and '79 had married transfer cases. The swap is doable but you'll need to do some tear-down, and while it's all apart you'll be looking at it thinking, "Should I rebuild this since I have it all apart anyway?"
bigcrunch
Jul 21, 2015 07:51 PM
projectdagger
Aug 28, 2009 10:23 PM
78fordf150ranger
25
Apr 4, 2007 06:08 PM
flcbell
Mar 31, 2004 10:36 AM
