C6 capacity?
Old Feb 23, 2014 | 01:47 PM
shane_lxi's Avatar
shane_lxi
C6 capacity?
Took my c6 apart enough to replace seals on the pump. Also drained the converted. It's been sitting on its tailshaft for about a week, so I'm sure it's good and empty, lol. How much fluid and what technique should I use.
Old Feb 23, 2014 | 02:49 PM
tom6433's Avatar
tom6433
I put 12.5 quarts of type f in mine last week. I think the original fluid was in it but the new type f is working just fine. I read up on this in other posts which was a lot of help. I ended up adding 6-7 quarts through the dipstick tube and then started it up and put it in D for 10-15 seconds, then in R. Did that a few times and then it finally started to want to go. Turned it off and added all but the last quart and a half. Took it for a short drive and added the rest. I hope that helps.
Old Feb 23, 2014 | 03:08 PM
rockittsled's Avatar
rockittsled
refill capacity is 24.5 pints
nitsua28
May 9, 2012 09:31 AM
projectdagger
Nov 29, 2008 12:19 AM
tuekwik
Jan 24, 2006 05:20 PM
sigtauenus
Nov 13, 2005 06:30 AM
76390FE
Dec 11, 2003 12:57 AM
