simple question
Old Feb 22, 2014 | 05:29 PM
1990-f250's Avatar
1990-f250
simple question
Hello. I have a question about a 1994 351w. I am in the process of doing an engine swap and need to get the wiring harness off of the engine. My question is do I need to remove the upper intake plenum in order to remove the wiring harness?
Old Feb 22, 2014 | 05:36 PM
Conanski's Avatar
Conanski
Yes the upper intake has to come off. If you can't get the tube to disconnect from the EGR valve unbolt the valve from the intake instead and wire it up so it doesn't fall over and break the tube while you're working. The EGR tube has a flexible mid section but it's fragile and cracks easily.
Old Feb 22, 2014 | 06:22 PM
1990-f250's Avatar
1990-f250
Ok thanks for answering all of my questions! You've been a great help
BjpouserXLT
Nov 3, 2018 06:42 PM
Benchwarmers6
13
Mar 22, 2016 08:45 PM
Duncansm
Jun 30, 2015 11:03 PM
Dave Rumbaugh
Oct 25, 2013 06:54 PM
fernesto
Jan 23, 2011 02:32 PM
