EVAP System Noise
Old Feb 21, 2014 | 11:13 PM
afarmerboy88's Avatar
afarmerboy88
EVAP System Noise
Hopefully someone can answer this for me......
2001 X, Limited, 6.8L
Recently, when i turn my X completely off and remove the key, I hear something that sounds like it runs on and off. I popped the hood and it sounded like it was coming from the EVAP canister. It will engage several times, even while my vehicle is off. Im not sure if this problem is related but sometimes when I turn my key off and remove it, my air will still be running if the switch for the air isnt turned off. Could this be related and point to a bad ignition switch? Or is this a coincidence and my ignition switch is bad along with a whole other string of problems within my EVAP system? I cant find any information on google and its driving me nuts. Thanks guys, any and all help very much appreciated.
Old Feb 21, 2014 | 11:41 PM
Hemmi06's Avatar
Hemmi06
The on/off thing may be your ABS.
The ABS cycles once when I turn they key to run in mine. Your key/ignition is where I would start.
Old Feb 22, 2014 | 06:36 AM
projectSHO89's Avatar
projectSHO89
If it's the ABS, it doesn't have to be the ignition switch. The ABS controller is continuously powered.
Need to specifically identify the source of the sound as well as all other "odd" symptoms.
Frankly, it sounds more like water infiltration into the fuse box area.
Old Feb 24, 2014 | 08:17 AM
afarmerboy88
Now that you mention it, roughly 4 or 5 days ago the ABS light was on. After driving down the driveway it disappeared. I just moved here to New York from Georgia. Needless to say, my battery has had to be jumped off a couple of times. Yesterday, I replaced the battery and it fired right up. No engaging noises like before, however, the ABS light was on. I drove it down the driveway and it disappeared. This morning, I have not seen the light. The only other "odd" thing that was going on was when I turn off the key, my heat or fan is still blowing. I can turn the fan off and it still runs. I turn the key to "on" or "ACC" and the fan will turn off. A lot of things going and throwing me in different directions.
Old Feb 24, 2014 | 11:04 AM
ExxWhy's Avatar
ExxWhy
This has happened to many, small windshield leak dripping into the wiring and causing all sorts of weird things. Give it a very thorough look under the dash.
Battery connections clean and tight?
Old Feb 24, 2014 | 01:06 PM
projectSHO89
That also supports the theory of water infiltration into the fuse box. All too common.
Old Feb 25, 2014 | 08:12 AM
afarmerboy88
When it warms up a bit, I'll try to make some glycerin water and check the windshield for peaks. I'll try and get out there today and check both fuse boxes for the water infiltration. I can't really go off of water in my carpet. Haha, my carpet is frozen from the snow on my boots. I'll try and get back on in a couple of days, I'm in the middle of in-processing at Fort Drum.
USArmyTaterness
Mar 28, 2012 11:49 AM
jbworm20
Feb 24, 2012 09:25 AM
Shimrra
Aug 18, 2011 07:27 PM
Fordbronco69
Nov 26, 2006 11:28 AM
tomucen
Aerostar
18
Feb 8, 2006 08:20 PM
