lift questions
Old Feb 20, 2014 | 08:47 PM
almonyspm1's Avatar
almonyspm1
lift questions
92 f150 4 wheel drive. My truck has a 3 inch body lift (original owner installed) I know some people hate them because of the safety factor, but I've never had problems. I don't really like the look of it though. Also with the truck being a secondary vehicle now, I want it to be done right and have fun with it. Question 1: what size tires could I clear right now with the 3 inch lift? (302/3.55) I have 32s right now. Question 2: what can I do as far as a suspension lift? If you guys want to just give me a link for a good thread that's fine. Also if you guys have links for kits or parts I would appreciate it. I don't need huge lift, I don't want to have to extend brake lines and stuff like that. Any help is appreciated
Old Feb 20, 2014 | 10:03 PM
blkF250HD's Avatar
blkF250HD
With your current engine and gear set up, anything larger than 33's is going to make it into a gutless slug IMO. Skyjacker and Rough Country are two companies that I can think of off the top of my head, there are many more. I'd eliminate the body lift before going installing the suspension lift. Typically combining the two is a no-no. Depending on how high you go, longer shocks and extended brake hoses may be needed. It would ruin your day to break a hose when the suspension goes to full droop in a hole or something.
Old Feb 21, 2014 | 07:40 AM
almonyspm1's Avatar
almonyspm1
Yea that's what I figured on tire size because of gear ratio. Thanks for the reply
regret
Dec 7, 2012 10:18 AM
Louie3
21
Nov 19, 2008 10:40 AM
Rocking M
1966 - 1977 Early Broncos
Mar 23, 2006 07:17 AM
OL934x4
Feb 28, 2003 07:54 PM
