Bronco II Ford Bronco II
power steering
Old Jun 30, 2003 | 02:01 PM
Stanstruck's Avatar
Stanstruck
power steering
My power steering pump is leaking (to say the lease). What's involved in fixing this thing? Can I go to some power steering fluid instead of Type-F and reduce the leaking any? (I'm reaching here, I know....)
thanks,
Stan
Old Jun 30, 2003 | 07:08 PM
Ken00's Avatar
Ken00
power steering
You really need to find the leak and repair to cure the problem, might just be a hose. Make sure you bleed the system properly.
Old Jun 30, 2003 | 09:23 PM
GrayRanger4x4's Avatar
GrayRanger4x4
power steering
If you have a 84-90 B2 I would get a new pump and hoses.The pumps are a pice of crap{fords better idea}. But you might get lucky and its just a bad hose. good luck!
Old Jun 30, 2003 | 11:01 PM
Willy McCoy's Avatar
Willy McCoy
power steering
If it's a pressure hose, just make sure you don't overtighten it at the pump end. I went thru two of 'em before I found out that the hose is supposed to be loose in the fitting there. I'd install a new hose and the first or second time I turned the wheel all the way over, the hose would pop it out the pump fitting. AutoZone was really appreciating the business too.
1999_Explorer
Sep 20, 2015 04:28 AM
johnstonmatt77
Sep 2, 2014 12:54 PM
89danford
Feb 17, 2014 04:35 PM
llljllollnlll
1978 - 1996 Big Bronco
Feb 11, 2013 07:02 AM
ItsAFord55
Apr 11, 2012 10:37 PM
