1999 F450 Dana 80 Detroit Locker No Spin
Over the weekend I installed my locker and swapped the 4.88 for 4.10 gears. Only got these 2 pictures sadly. The oldest boy knocked a tv tray over on the baby so I spent most of Saturday in the ER with him waiting for stiches on his nose. he is ok though tough little kid. My Dad was helping me and he got the Pinion depth set while I was gone. He said it took a few times to get it correct. I got the carrier shimmed good on the third try it was just a pain to keep everything lined up together and push it in. the carrier stuck out just past the bearings so I had to hold the race and shims in place and push it in as a unit.
I am very happy with the results so far. Unlocking and locking is hardly noticeable. It will break both loose on a corner if you step on it too much. (edit if you put it to the floor when turning taking off at a stop sign. had to "test" and see what would happen) Driving to work today on wet pavement I spun it unlocked turning left at a stop sign when I took off the left slipped a touch then the right locked back in and pulled nicely. No big clunk or bang just the truck accelerating. the only think I notice is when you are going down the road and lift off the throttle. You can feel the parts in the locker move as the wheels start to "drive" the driveline. Not bad at all. the part number was 225SL105A the "L" means it is the "new and improved" design that is supposed to disengage and engage smoother so that may have been a help. no clue when that was implemented because I bought the locker second hand but new in box. it looked like it had been on a shelf some time.
I am very happy with the results so far. Unlocking and locking is hardly noticeable. It will break both loose on a corner if you step on it too much. driving to work today on wet pavement I spun it unlocked turning left at a stop sign when I took off the left slipped a touch then the right locked back in and pulled nicely. No big clunk or bang just the truck accelerating. the only think I notice is when you are going down the road and lift off the throttle. You can feel the parts in the locker move as the wheels start to "drive" the driveline. Not bad at all. the part number was 225SL105A the "L" means it is the "new and improved" design that is supposed to disengage and engage smoother so that may have been a help. no clue when that was implemented because I bought the locker second hand but new in box. it looked like it had been on a shelf some time.
a Detroit locker in a daily driver isn't for everyone though. as someone who lives in a snowy climate, they can be disastrous in limited traction situations at speed, and low speed in snow/ice on a side-slope can have you in a ditch as well.
anyone looking into a positive traction device in a daily driver should consider the detroit trutrac LSD. i haven't actually used one but i've heard great things - and no clutches.
great addition to the dually, glad that it's working good for you.
Yep. I considered that first but my Dad had those in his 78 F150 and thought I would like the locker better. I was on the fence between the 2 so I took his advice since he would be helping with the install. edit Needed to avoid the I told you so and other fatherly stuff
OK...I need a lesson here...to me a Detroit Locker is locked solid all of the time, like there is one solid axle coming across from one side to the other. Brandon is describing what sounds more like a LS to me. I'm pretty clueless about what goes on inside the pumpkin and I don't know what makes a LS lock either. Under what circumstances is the DL locked or not locked?
Here is a video that shows it somewhat. Start at 2 minutes
SuperDutyScaler
1999 to 2016 Super Duty
211
08-22-2021 02:23 PM
paulg
31
10-11-2001 08:39 AM
paulg
04-24-2001 10:31 AM
