Way off topic but.......
Old Feb 18, 2014 | 11:12 PM
The Masked Rider's Avatar
The Masked Rider
I know this is way off topic but I'll bet for our members that are copter pilots, it would cause a little pucker power.......... ;o(
Helicopter's Rotor Catches Steel Rope
Old Feb 19, 2014 | 04:49 AM
fabmandelux's Avatar
fabmandelux
FTE Remembers
Moved to GNAC.........
Old Feb 19, 2014 | 05:18 AM
ckal704's Avatar
ckal704
Holy Moly! That is clearly a "change your drawers" situation.
Glad nobody was hurt, considering what could have happened.
Old Feb 19, 2014 | 06:12 AM
hanklin's Avatar
hanklin
looks like he almost flopped out. Thank you Seatbelt!!
Old Feb 19, 2014 | 11:53 PM
ford2go's Avatar
ford2go
Holy C*ap!!
Now that's a bad day
hj
Old Feb 20, 2014 | 01:37 PM
Wolfracing's Avatar
Wolfracing
That line looked a bit short. Looked like the one guy tried to flip it out of the way and it went right into the blade. How nobody got hurt is beyond me.
Old Feb 20, 2014 | 01:53 PM
Stewart_H's Avatar
Stewart_H
He didn't flip it out of the way, he caused the problem when he jumped up, grabbed the cable, and pulled it taught. His action moved the cable directly into the rotors. Idiot needs to be fired.
Stewart
Old Feb 20, 2014 | 02:26 PM
Wolfracing's Avatar
Wolfracing
Stewart
I having trouble seeing that. I don't see him jump. It doesn't look like there is much slack in the line, meaning those blades were mighty close anyhow and probably going to be a problem in the next moment. I think he pulled out on the cable and when it rebounded it pulled his hand in....making it look like he flipped it in. Pretty easy to be critical from a desk chair.
Old Feb 20, 2014 | 03:44 PM
Stewart_H's Avatar
Stewart_H
1:44 into the vid. It's clear as day. He jumps up and grabs the cable which pulls it tight, changing the angle of the cable which pulled it into the path of the rotor.
I agree. But the guy jumping up and grabbing the cable is still the reason it happened.
He jumped up and grabbed the cable. When he landed, it pulled the cable into the rotor.
Yes, it is. It's very easy. Your point is??
Stewart
Old Feb 20, 2014 | 04:04 PM
Wolfracing's Avatar
Wolfracing
That WAS my point.
Old Feb 20, 2014 | 06:17 PM
56panelford's Avatar
56panelford
I see where the guy jumped that Stewart is talking about. I does look like the blades would have made contact regardless but it looked like a risky maneuver regardless. Sure is easy to ruin a million dollar plus piece of equipment though.
Old Feb 20, 2014 | 06:34 PM
Stewart_H's Avatar
Stewart_H
That WAS my point.
Ok, just making sure because sometimes it's not clear when it comes to perception, nuances, and implications in posts.
Stewart
Old Feb 21, 2014 | 01:55 AM
r___r's Avatar
r___r
Luckily the pilot was able to walk away from that and no one on the ground got taken out by the shrapnel.
It looks like the job of setting the tower was just completed. I see a few things that may have contributed to the incident.
The long-line was not calculated long enough when the tower(probably laying horizontal on the ground) was rigged up to the helicopter from the beginning, before the lift.
Maybe the pilot knew it was short and tried to land anyway, saving the guys on the ground from having to climb the tower to disconnect the cable (would've taken a minute or two).
Usually the guy not wearing a hard hat on a jobsite (like the guy jumping for the cable) is usually the boss, foreman, or journeyman...at least in my experiences.
Old Feb 23, 2014 | 09:34 AM
nitrogen's Avatar
nitrogen
pilot should have released his end of cable before landing. Far too many people in landing area. VERY VERY lucky no injuries. The chopper? She's scrap boys
Old Feb 23, 2014 | 03:54 PM
The Masked Rider
After all you investigators posted your findings, g I went back and watched it again a few times. I have to agree that the cable looks like it was pull and set off the accident a little sooner but I still think it would have happened anyway. If he was going to land with the cable still attached, IMO, it was way TOO short. Doesn't look like they have too much more room to land anyway. WHICH brings up the second things mentioned. WHY wouldn't there not be a way to disconnect the cable before he tried to land in such limited space. Climbing the tower sound good if you have the ***** to do that with a cable attached to a chopper flying directly above you. Not sure the tower was even stabilized to climb.
TOO many mistakes made from the very beginning. (Poor engineering - cable not long enough / No quick detach / not enough area to land / way too many people running around the area.) OSHA would have a field day with this one. BUT, since its was in another country, guess we'll never know
And as one of you commented on, incredibly amazing no one was hurt. It very well could have gone WAY FUBAR...........
Greywolf
Nov 15, 2009 07:23 AM
Snowbunny
146
Apr 24, 2008 02:49 AM
3broncocrazy
34
Feb 11, 2008 04:48 PM
Waxy
29
Feb 16, 2004 08:10 AM
