9 inch vs. Explorer L73
Old Feb 18, 2014 | 04:39 PM
das54's Avatar
das54
Help me decide. Remember, my project is a low buck build but this issue is killing me. I have no traction on wet roads and I think posi traction (originally a chevy term) will solve my problem. I have a 9 inch open 2.91 with 1-3/4 brakes. I want to install an Eaton truetrac (p/n 912A587) but it won't work with my gears (trac loc won't either). Truetrac, 3:50 ring and pinon, bearings, seal and gasket will cost a grand plus I gota learn how to install the gears. I probably aught to replace wheel bearings while I'm at it. OR I buy this for only $250. Probably a lot more work fitting it to my truck and TrueTrac is probbly better than tracloc and the 9 inch is way cooler but rear disk brakes are probably better. After selling my 9 inch this will be about $1000 cheaper. Even if I put a new TrueTrac in the 8.8 I'll be $500 cheaper than building the 9 inch.
Old Feb 18, 2014 | 07:00 PM
pholmes350's Avatar
pholmes350
I picked up an 8.8 with 3.73s posi and disc brakes and sway bar. Swapped the whole thing in including the sway bar. All I had to do was weld spring perches on the top side. I set the perches up at the same width and angle as the old ones. Keep in mind the pinion is offset about 2" to the right but shouldn't be a problem.
Old Feb 18, 2014 | 07:05 PM
pholmes350's Avatar
pholmes350
Oh yea and was out of an explorer and put it in a 53 F 100
Old Feb 18, 2014 | 07:25 PM
GMbusa's Avatar
GMbusa
What year explorer is optimal?
Old Feb 18, 2014 | 07:41 PM
topmoo's Avatar
topmoo
Disc brakes on Explorers from 2000.
Old Feb 18, 2014 | 07:48 PM
Wayne Waldrep's Avatar
Wayne Waldrep
What did you do to adapt the rear end pinion flange to the driveshaft? And what driveshaft/tranny?
Old Feb 18, 2014 | 07:58 PM
pholmes350's Avatar
pholmes350
Here's a link to some good info on rear end swaps:
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
I also got the aluminum driveshaft out of the exploder. I will have to get the driveline shop to build a shaft with the flange on the backend and the correct yoke to fit the stock 3 speed on the front.
Old Feb 18, 2014 | 08:34 PM
ryans88gt's Avatar
ryans88gt
you can get a flange for the rear of the driveshaft
Mustang Driveshaft Flange Yoke fits 7.5 and 8.8 inch Rear Ends 1310 Series with small Ford bolt pattern
Or get a 8.8 U-joint yoke.
http://www.summitracing.com/parts/ms...FStgMgodPxEASw
either will solve the driveshaft to 8.8 issue.
Old Feb 18, 2014 | 08:35 PM
ryans88gt's Avatar
ryans88gt
my explorer 8.8 bolted right in above the springs. I did use some shims to get the angle right. Also had to build some shock mounts.
Old Feb 18, 2014 | 08:50 PM
CharlieLed's Avatar
CharlieLed
Disc brakes actually started in 96...
The year is not so important, other than mileage, than the model of the Explorer...get an XLT, it comes standard with Trac-Loc, 31 spline axles, and 3.73 gears. The end flanges on these rearend housings are the same as the big bearing 9 inch rearends but the tubes are actually 3.25 diameter...much stronger.
Old Feb 19, 2014 | 07:29 AM
topmoo's Avatar
topmoo
You are right Charlie, mine is a 2000. I forgot the comma. Another nice thing about the Explorer (31 spline 3 1/4" tube w/disc brakes) rear is that the emergency brake is a separate small drum brake that is fairly easy to run cables to.
Old Feb 19, 2014 | 09:24 AM
CharlieLed's Avatar
CharlieLed
When I built the 9 inch for my truck I bought the rear brake kit from FRPP brand new...it was around $400 as I recall. These brakes were so popular that Ford brought them out as a kit for all of us who wanted to dump the drums. The last 8.8 I bought (a 2000 year model as well) I got for $120 at a yard here in town...that was a super price for this area but even at the going rate, buying a complete rearend is much cheaper than buying the FRPP kit new.
As an added note, LOKAR makes some VERY nice e-brake cables for these kits/brakes.
Old Feb 19, 2014 | 04:26 PM
das54's Avatar
das54
All very good info. I like the sounds of this and the info for the yoke flange adapter. I might still have to get the drive shaft length modified, hopefully shortened.
Old Feb 19, 2014 | 04:28 PM
das54's Avatar
das54
is there a difference between std. and XLT model rear ends. I can't find any other forums or web sites that talk about this.
Old Feb 19, 2014 | 05:23 PM
CharlieLed's Avatar
CharlieLed
The base model Explorer has 28 spline axles and no TracLoc. I believe that this configuration is the same as the Ranger truck. Lots of sources out there on the web, here is just one: The Ford Explorer 8.8-Inch Axle Swap
