1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 f250 superduty 5.4 surging
Old 02-17-2014, 07:37 PM
dunhamc's Avatar
dunhamc
dunhamc is offline
hi everyone my truck at idle sounds like it has aftermarket cams and the exhaust coming out of the tail pipe smells really rich. when driving down the road my heater controls default to defrost. Also when I fill up with gas it takes forever to get it to fill all the way. im lost on where to begin with the problem [ I did check the tank vent hose and their is no blockage] Possible vacuum issue? all input will greatly be appreciated! Thanks guys!
Old 02-17-2014, 08:23 PM
redford's Avatar
redford
redford is offline
Received 1,603 Likes on 936 Posts
Welcome to FTE, dunhanc!
Is there black smoke?
That points to a vacuum leak.
Might be an unrelated fuel tank vent or evap charcol filter issue.
Start with the vacuum leak, find it and fix it, then evaluate again what the truck is doing.
Old 02-17-2014, 08:39 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Most likely place for a vacuum leak on these trucks is the hose going to the PCV valve, there is a elbow on the back side of the manifold that cracks and causes the leak,,
Old 02-17-2014, 08:44 PM
dunhamc's Avatar
dunhamc
dunhamc is offline
their is no smoke of any kind coming from the truck at all. when the truck is cold and you first start it and its in high idle its fine, as soon as the truck comes off high idle it very rough lope idle
Old 02-17-2014, 10:03 PM
redford's Avatar
redford
redford is offline
Old 02-19-2014, 11:16 PM
FordF250Lariat's Avatar
FordF250Lariat
FordF250Lariat is offline
My heating unit at times will change to defrost settings, especially when put on "auto" this is because my actually climate control module is going bad. Theres people out there that will rebuild them for half the price of buying a new one from Ford. Anyway, perhaps you do not have a vacuum leak but your EATC is going bad. Heres a helpful link,
Old 02-20-2014, 05:20 AM
redford's Avatar
redford
redford is offline
The heating changing to defrost is an indication of a vacuum leak, not a bad EATC.
Old 02-20-2014, 06:23 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Maybe it it is. The o-rings in the vacuum solenoids go bad and leak. Readily replaceable by a handy person.
In any event, it IS a vacuum leak.
Old 02-23-2014, 10:00 AM
dunhamc's Avatar
dunhamc
dunhamc is offline
Good morning guys! After our recent snow storm my engine bay got packed with snow and shorted some coil packs I learned not to drive through 5foot drifts lol. Got that fixed and I also found that one of the two vacuum lines that go to the egr controller was rotted completely off! I'm still working on it I will let you guys know further more when I get done.
Old 02-23-2014, 10:55 AM
dunhamc's Avatar
dunhamc
dunhamc is offline
And those Orings you are talking about where are they located at?
Old 02-23-2014, 04:50 PM
projectSHO89
In the EATC.
jerryparks
05-29-2015 11:40 AM
krazeyelf
12-11-2010 04:27 PM
nininchnail
1997-2006 Expedition & Navigator
04-20-2006 09:40 AM
4x4_EB_Explorer
06-11-2002 08:52 AM
Quick Reply: 99 f250 superduty 5.4 surging
