Brake cable rubbing shock
Old Feb 17, 2014 | 03:46 PM
gwuister's Avatar
gwuister
It's time to do the shocks on my 01 Ranger. I was crawling around under the back of the truck and see the parking brake cable has just about rubbed a hole in the passenger side rear shock.
It doesn't look like there is any other way to move the cable.
Is this typical?
Truck is a one owner and completely stock.
Any thoughts?
Old Feb 18, 2014 | 06:51 AM
Josh S's Avatar
Josh S
Mine has been rubbing in the same place for years and years.
Old Feb 18, 2014 | 08:31 AM
pawpaw's Avatar
pawpaw
You must have missed this in your info search. https://www.ford-trucks.com/forums/5...ubs-shock.html
Old Feb 18, 2014 | 09:05 AM
gwuister's Avatar
gwuister
Thanks pawpaw, but my search skills didn't find that thread...
I'm planning to put on some air-shocks but need to see if that cable might interfere with the rubber air bag on the shock...
Old Feb 22, 2014 | 07:49 PM
rgp's Avatar
rgp
I will say that it is typical. I use my 2001 Ranger parking brake all the time. A couple years ago it would not retract. Crawling underneath I found the rubber jacket worn sufficiently for water to enter and therein produce rust. The cable that is within the jacket will not slide when jammed with rust. I replaced the cable and routed it so it does not rub on anything.
pawpaw
20
Apr 10, 2017 08:35 AM
AWC
Sep 22, 2014 03:17 PM
TexasGuy001
Oct 21, 2010 03:46 PM
dehamma
Dec 2, 2005 03:17 AM
