Steering Stabilizer
Old Feb 17, 2014 | 01:39 PM
Bri21074's Avatar
Bri21074
Steering Stabilizer
This Past weekend I used my truck to go outand pick up a new race car. One the mainreasons I go this truck was so that I could start trailering my car to thetrack, the tracks are typically a fairly long haul the closest one being 90 milessome are 300. One thing that I hadhappen was terrible bump steer I was wondering if a steering stabilizer wouldhelp and if so what you would recommend.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
My truck is a 1996 F250 XL 5.8L with an Manueltrans. <o></o>
<o></o>
AlsoI probably need to replace the shocks and the front springs have sagged. Any recommendation for this would be helpful.
Old Feb 18, 2014 | 08:06 AM
Puddy's Avatar
Puddy
If your worried about the slop, I would recommend you inspect all steering linkages and replace.
I was able to tow a 14 mustang GT across the country and back.
I see stabilizers as a off-road thing so the wheel does kick back at you when you hit something
Old Feb 18, 2014 | 12:10 PM
DAT2109's Avatar
DAT2109
How much slop do you have in your steering wheel before the front wheels start turning? Bump steer or death wobble are scary! especially with a trailer
Old Feb 19, 2014 | 10:41 AM
Bri21074's Avatar
Bri21074
The steering is actually pretty tight, itwas recently inspected. The shocks doseem warn. I was able to run downthe highway at 60 to 65 with the trailer. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Feb 19, 2014 | 03:36 PM
MFJ's Avatar
MFJ
The van guys seem to like having a stabilizer added. Was available on ambulance package vans, and all the holes are there to add it. https://www.ford-trucks.com/forums/1...ering-fix.html
Might be worth looking into. Not sure if it was a factory option on trucks.
Newer front brakes from a 2008-up van should fit a 2wd truck as well. Thicker rotors, needs new rotors-calipers-brackets.
bradpowell3557
Dec 8, 2015 02:46 PM
sticks25
15
Oct 1, 2008 01:53 AM
Palomino
1997 - 2003 F150
Jun 3, 2007 10:36 PM
kbelanger
Aug 8, 2004 07:46 PM
