USB Panel mount....Rich?
Old Feb 17, 2014 | 08:40 AM
Dan V's Avatar
Dan V
With the fact that the Super Duties are pretty ancient technology, and electric peripherals consist of a cigarette lighter. Has anybody thought about installing something like this? A dual port would be nice though.
iS43 HubVolt Universal USB Charging Kit :: Accessories
Old Feb 17, 2014 | 08:48 AM
F250_'s Avatar
F250_
When I start my switch customizing in my cab, I'm probably going to go with something from these folks which will include a couple of USB ports.
Gaugeplates.com Your home for custom gauge panels.
Old Feb 17, 2014 | 09:46 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Go for it. Its pretty simple.
Old Feb 17, 2014 | 10:46 AM
nlemerise's Avatar
nlemerise
That charging kit you linked to Dan only has a 500mA output...which means it can't charge iPads and some other devices which require 1000mA charge capacity. I have been using a real cheap plug-in one that provides two usb connects and runs 1200 mA charge capacity in each usb port.
Old Feb 17, 2014 | 10:53 AM
Tugly's Avatar
Tugly
I have two devices similar to this (one for each vehicle) [LINK]
It saves the bother of wiring, it's very tidy, and I still have my two plugs available when needed for things like my 50W inverter or the trouble lights I own.
This is the bad boy that I transfer back and forth, though - it rocks. I have the black one because it's more manly. [
LINK LINK
Old Feb 17, 2014 | 12:07 PM
SpringerPop's Avatar
SpringerPop
Remember, USB will also be eventually supplanted by some newer technology, leaving your instrument panel with something that's likely (then) more obsolete than the everyday cigar-lighter-style plug.
I use the plug-in adapters. Whatever that newer style charging becomes, the adapters will be made for it, too.
Pop
hotfalcoon
Nov 9, 2018 11:44 AM
77460ford
Jan 28, 2011 05:47 PM
bigwin56f100
20
Feb 21, 2010 01:14 PM
4tl8ford
Jun 9, 2008 06:36 PM
51PanelMan
21
Nov 5, 2006 09:11 PM
