Im building a pretty stout 390 for my 69 F100 and want a manual trans for sure. I just cant justify spending 2500 plus on a TKO. Any suggestions on factory ford 4 speeds that are pretty burly?
Thanks for the info! The more I look into it I might as well spring for a 5 speed. Get to blast through the gears and have OD would be worth it. I would be close to spending the same for a decent top loader it looks like.
One thing to keep in mind with David Kee's Toploaders is they're all new parts and you're not going to break it in your lifetime. A small block Toploader will hold up fine behind a 390. I used to run em behind a 427.
