Cleaning Cyl. Head Bolt Holes
Ford 400.
I am getting my heads back from the machine shop tomorrow and would like to get my truck running again after having blown a head gasket. I have all new Felpro gaskets, the block surfaces are all cleaned up and I have everything else I need to get the job done except one thing. I bought a set of ARP cylinder head bolts but I don't want to put it back together without getting the bolt holes in the block cleaned out so the heads will torque down correctly. I am going to try to track down a thread chaser in the morning but I don't know if I'll have any luck. Here are my questions:
1.) The bolts are 1/2 inch but I don't have them here with me now so I can't look at what the thread count is. If someone happens to know what thread these bolts are it might help me to track down a thread chaser first thing in the AM.
2.) if I can't find a thread chaser what's the best way to clean out the bolt holes? I hate to use a tap and brake cleaner but I might have to give that a try unless somebody knows another trick.
Any ideas are appreciated.
Thanks.
Thanks.
Ford 400.
Thanks.
Thanks.
Cut a groove down the side of the one of the old bolts, use a cut off wheel or something that will leave a clean edge like a tap has, run it in and out, blow out the hole with compressed air if you can, usually a bottle brush, brake clean and compressed air will clean the hole enough, unless there was alot of rust in the holes.
Good luck.
Good luck.
F250Rob
01-14-2005 08:08 PM
daggerNC
10-28-2004 04:05 PM
frankster123
03-03-2003 05:24 PM
