highboy PS using 78 Bronco box
Old Feb 16, 2014 | 04:16 PM
trilogymac's Avatar
trilogymac
Well after reading as much info as possible here, on the many different ways to install PS in a highboy, I chose to use a 78/79 Bronco box with the rotation reversed. This is also known as a Rockcrawler or 4x4x2 box. The main reason was to sidestep the cutting and welding of the crossmember.
Parts used:
1. Redhead 78 Bronco box reverse rotation (outside of frame mount)
2. Wild Horses 78 Bronco lower steering shaft
3. Wild Horses Saginaw Pump kit for a 351M
4. 1/2" Grade 8 bolts and hardware
5. 3/8" thick plate with 1-1/4dia. x 1/2" thick bosses welded to the plate for added support inside the frame (no welding on the frame)
6. Moog ES150 L& R ball joints for the drag link
7. Bulletproof steering tube for the adj drag link @ 9-1/8" long. My center to center drag link length came out to 12-3/4"
8. 78 Bronco PS return line from Bronco Graveyard.
9. 78 F250 4x4 pitman arm
I'm not going to do a step by step as it was VERY similar to the other installations except for one thing worth noting.
I milled the 4 index "keys" out of the pitman arm. The reason was so that I could index the arm 2 teeth (20 degrees) to the rear for tire/pitman arm clearance at full right lock. This is probably the one thing unique to using this box, and it worked great.
I hope this helps someone that decides to go this route.
Trilogymac
Steen Boat Willey
Sep 17, 2018 05:02 AM
78 Ford F150 460
34
May 12, 2018 11:58 PM
ManfredVonRichtofen
Jan 22, 2016 09:26 PM
racer30
Ford Truck Parts for Sale
Dec 7, 2012 09:21 PM
74fordtruck
Offroad & 4x4
Nov 1, 2004 12:18 AM
