Replace #8 push rod?
Old Feb 16, 2014 | 02:19 PM
KRDiesel's Avatar
KRDiesel
What is required to replace #8 push rods, rockers and bridges?
I have a poping through the intake, Listening to the videos it should like a push rod. only been doing it for 140,000 miles though
Old Feb 16, 2014 | 04:48 PM
BLADE35's Avatar
BLADE35
well if it was me going in I would replace all push rods to the updated shorter ones to save lifters
Nothing major to change them but spin the engine prior to startup
Old Feb 16, 2014 | 04:51 PM
npccpartsman's Avatar
npccpartsman
Basically it involves this:
File Type: pdf
Old Feb 16, 2014 | 06:16 PM
KRDiesel's Avatar
KRDiesel
Wow, that looks like a pain.
Old Feb 16, 2014 | 08:50 PM
9228.bobcat's Avatar
9228.bobcat
Thanks for that, I needed to smile.
Old Feb 17, 2014 | 06:38 AM
npccpartsman
If you're studded you can remove the stud nuts one at a time but if they're TTY bolts use the tool. The alternative might be a ruined camshaft and you know what kind of nightmare that is.
Old Feb 17, 2014 | 07:37 AM
Asheville Engine's Avatar
Asheville Engine
Former Vendor
I would be concerned about WHY you are getting the popping. The # 8 cylinder is usually the first one on a 6.0 to collect anything that goes through the intake. Before you start taking things apart, the most likely cause in a 6.0 would be a failed lifter. To find out, you can usually drain the oil and run a magnet through it to see if there is a bunch of metal in it. The engine will usually stop running when you lose a lifter because the debris goes through the LPOP and you lose oil pressure to the HPOP but you may have caught it real early so that's where I'd start. If no debris, inspect the pushrods to see if any are bent. If they are not bent, then you may have a damaged valve. Again, the big question is why...Good luck!
Old Feb 17, 2014 | 07:54 AM
9228.bobcat
Yea without having it apart its kind of a guessing game what is wrong with it. I would pull the valve covers and check the rockers and bridges. Might be a broken rocker or the plastic clip may of broken. Need to get it fixed before your popping noise stops permanently.
Old Feb 17, 2014 | 09:03 PM
KRDiesel's Avatar
KRDiesel
I will look into it this weekend, This has gone on for 6 years and 140,000 miles.
Old Feb 17, 2014 | 09:10 PM
DerbyPowerstroke's Avatar
DerbyPowerstroke
Bad lifter didn't stop mine from running but ate the cam.
Old Feb 18, 2014 | 08:13 AM
Asheville Engine
Former Vendor
If any of the plastic clips are broken or missing, that is not the problem and don't worry about replacing them. Their only purpose is to hold the rocker arms during assembly.
Hank79
Sep 16, 2018 11:46 AM
Eric Kropp
Aug 27, 2014 11:06 AM
Blade79
Maryland Chapter
31
Aug 13, 2010 05:56 PM
UM-REBEL
May 30, 2008 08:49 AM
