I have always used pro comp on every truck I have owned. How high are you looking to go? I stay with PC as I have never had an issue with any of the suspension lifts I have had.
I rub the drivers leaf spring at full lockout but that is not an issue of the lift, that comes from the back spacing on the type of wheel you have and the width of the tire. I have a 4" back space so I rub a little. Ideally, I would like to find a set of wheels I like with a 3.75" backspace and I would be gtg.
running a 4" PC lift with 37's. Rub fender liners on bumps a bit.... Biggest issue I'm having is the drivers side front likes to sag compared to the rest of the truck. Oh and if you go PC do yourself a favor and get different shocks. The ones that come with the lift are horrible.
