No front turn signals?? HELP!
Old Jun 30, 2003 | 12:45 AM
79_custom's Avatar
79_custom
I got a 79' F-100, The front turn signals doesnt work one bit.. I changed the bulds and checked the fuse.. I even put a singnal Relay switch in and still NUTTIN..I have rear signals and the instrument panel turn signals falsh like they should.. Not fast like I got a bulb blew..Im clueless, please help!!!!!!
-Custom
Old Jun 30, 2003 | 08:50 AM
mueckster's Avatar
mueckster
Are the marker lights in the front working? If not, check the ground wiring to the sockets. If all of this is OK, check the power coming from the turn signal switch harness below the steering column. The connection could be pulled apart slightly or you could have a bad turn signal switch.
Old Jun 30, 2003 | 02:07 PM
Franklin2's Avatar
Franklin2
The hazard switch could be in the mix too if none of the above checks out. Observe what color wires are going to your front turnsignals. You should be able to find these color wires in the steering column. You could also take a testlight, and probe these wires with the signal on. The testlight should flash on and off when you probe the wire if the other end of the test light is grounded.
Old Jun 30, 2003 | 06:55 PM
sparky's Avatar
sparky
Well the dash indicator light is tapped off the front turn signals...so if it is flashing the turn signal switch is working and power is heading towards the front turn signals.
As stated check the grounds, they should be black wires on the rad support usually.
The front RH light has a white/blue striped power wire and the LH has green/white striped power wire.
Old Jun 30, 2003 | 11:11 PM
79_custom's Avatar
79_custom
Thanks Guys, I'll check it out tomorrow...
Old Jul 1, 2003 | 01:20 PM
79_custom's Avatar
79_custom
I had a wire into at the switch going to the front.... I guess it was the wear over time... Its all good now...
_custom
