Winter Camping
Old Feb 23, 2014 | 08:44 AM
nitrogen's Avatar
nitrogen
so far under the blankets has been ok, the getting under them was a bit nippy. Leads to cuddling so it's all good :-)
It does lead to some condensation buildup on the walls, and windows. That certainly is one benefit to having a camper that is worth nearly nothing, you're not afraid to go anywhere and do anything.
Old Feb 23, 2014 | 08:46 AM
2006lariat's Avatar
2006lariat
Cuddling leads to babies.
Old Feb 23, 2014 | 09:21 AM
nitrogen's Avatar
nitrogen
Which leads to bigger RV's and bigger trucks, so what's the downside? :-)
At 45 with no luck in that department, we're not too concerned, seriously shocked if we end up having Abraham's luck.
Old Feb 23, 2014 | 09:49 AM
snowdog79's Avatar
snowdog79
We went out when we had our slide-in, and overnight it dropped to -5. How do I know? That's the temp the F350 showed on it's outside temp display when I had to go out and start the truck to recharge the camper's battery at 2am. We were at a National Forest campground with no hookups, and the under-sized, single battery they put in the camper wouldn't run the furnace (set at 55) for 5 hours. And it was a fully insulated, winter ready camper, heated tanks and all. I woke up because it was so cold in the camper, around 40. Not enough juice in the battery to turn on a light. Brrrr!
Old Feb 23, 2014 | 09:50 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Then at 64 you'll have one like the one in my picture. Just to relax in comfort.
FLgargoyle
South Carolina Chapter
Jan 25, 2014 03:49 PM
Fomoko1
13
Feb 10, 2009 09:42 PM
Fomoko1
28
Mar 22, 2007 11:25 PM
truckertaz
Iowa Chapter
Mar 10, 2005 02:13 PM
