Numberdummy off topic
Old Feb 14, 2014 | 10:26 PM
larryb346's Avatar
larryb346
I wonder if you could use your magical parts finding ability. I need drivers and pass. side windshield wiper towers for my 39 ford coupe.
Thanks
Larry
Old Feb 14, 2014 | 11:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks
Larry
I assume you're asking for the R & L pivots that the wiper arms/blades attach to.
Besides the pivots, there's a gasket, spacer and a nut per side. 1939 Ford passenger car (except convertible & station wagon) is one year only.
Early Ford Store located in San Dimas CA (earlyfordstore.com ~ 909-305-1955) has TONS of used early V8 parts. Also has NOS & repro parts.
1928/48 Ford Passenger Car & 1928/47 Ford Truck Chassis Parts Catalog available on a C/D from hipoparts.com
Ford 'nuts' refer to this as the green bible, cuz the original bound paper catalog has a green cover.
Old Feb 15, 2014 | 10:45 AM
larryb346's Avatar
larryb346
Yes sir. That is exactly what I am looking for. The splines on mine are worn and the wipers arms slip. This has been a issue for several years and I had hoped you might, in your parts search, find a dealer someplace with a new set.
I appreciate your help.
Larry
Old Feb 15, 2014 | 12:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Larry, I don't know how yours are constructed, but check out this post I did a while back. If you can remove the old splined hub from the shaft, these ANCO adapters would probably fix them.
https://www.ford-trucks.com/forums/1...ic-wipers.html
Old Feb 15, 2014 | 12:47 PM
larryb346's Avatar
larryb346
Thanks Ross
These are tapered and have very fine splines. It has been a issue since the car was built in 2004 It was built as a show car and was not too big a deal as long as that was the only driving. Pat and I have decided to stop showing and to drive the wheels off it so now I am going to have to deal with fixing the wipes. I will have to drop the headliner to get to them and will see what i have to do to fix it. I was hoping he might come up with some at a dealership. If I can't get some good ones, I will do as you suggested, and come up with a newer type to retrofit.
Old Feb 15, 2014 | 03:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Send me an email, Larry, I have a set of tapered splines that may work for you, Doc actually gave them to me.
Old Feb 15, 2014 | 05:00 PM
NumberDummy
1939 Ford Passenger Cars except Convertible & Station Wagon:
91A-17552 .. R/S Shaft & Connecting Arm-Windshield Wiper Pivot.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
91A-17553 .. L/S Shaft & Connecting Arm-Windshield Wiper Pivot.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
ANTIQUE AUTO SUPPLY has TWO.
Old Feb 15, 2014 | 06:34 PM
51fred's Avatar
51fred
Bill, I have been looking all over for the accelerator return spring 7hc-9737 and the safety catch spring 1c-16862-b. These are for my 51 F-1 with the 226. Any up your magical sleeve for those?
Old Feb 15, 2014 | 07:25 PM
NumberDummy
Originally Posted by 51fred
Bill, I have been looking all over for the accelerator return spring 7HC-9737-A and the safety catch spring 1C-16862-B. These are for my 51 F-1 with the 226.
7HC-9737-A .. Accelerator Return Spring / Obsolete
1C-16862-B .. Spring-Hood Front Auxiliary Catch / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old Feb 15, 2014 | 07:37 PM
51fred's Avatar
51fred
Thank you Bill! I will call on it Monday.
Redworks
Apr 17, 2016 04:48 PM
lbrauer
Apr 16, 2010 12:40 PM
es2rider
Apr 6, 2010 12:53 PM
DCC
Oct 16, 2004 09:25 PM
