460 idling high
Old Feb 17, 2014 | 10:30 AM
powerstroker100's Avatar
powerstroker100
Originally Posted by rla2005
Your closed throttle TPS voltage is right on the border of being too high. I tried watching your video but I had too much buffering to get an accurate count. Once or twice I did see a code related to TPS output, but I would not be 100% comfortable to say it is bad.
I did notice your tach did not read Zero with the truck off?
Personally I have not had any success using the spray method to find a vacuum leak on a fuel injected engine. I find testing each vacuum circuit with a handheld vacuum pump/gauge is the only to know for certain.
If the PCM is sensing a lean condition, caused by unmetered air aka vacuum leak, it will dump in fuel to compensate.
Originally Posted by subford
Reading the flashes I get:
KOEO - 116 - Cold Engine coolant - ECT
KOEO - 636 - Cold Transmission oil - TOT
KOEO - 114 - Cold Intake Air below 50 deg F - IAT
CM - 111
OR
No Codes at all.
thanks for your responses guys, I'm going to try and adjust my tps to see if I can get the closed idle a little lower, I really need to go buy a vacuum gauge, I also want to buy a fuel pressure gauge to see if maybe I have a leaking injector, I pulled a lot of the stuff on the intake off yesterday looking at vacuum lines, I didnt find any leaking however I did break the 5/32" line foing to the fuel pressure regulator so I have to get new hose today
should anything be done about code 636(transmission oil cold)? or cold intake air below 50*f?(114) its been 10*-29* here the last few days do these codes mean sensors are bad or that the truck knows its cold out?
I feel I'm going to have gray hair when I figure this out its driving me nuts
Old Feb 17, 2014 | 11:21 AM
subford's Avatar
subford
No, all codes are normal for a cold engine, transmission and the outside air temp below 50*F.
Yes your truck knows that it is cold out.
Old Feb 17, 2014 | 11:59 AM
powerstroker100
Hey Rla2005 you have a good eye, I didnt notice that when I turned Key on with the engine off the tach jumped up I'm not sure whats going on there
ok thanks, on my way to dmv to get this beast on the road then running around to get some tools to help Diagnostics, I will post back
Old Feb 17, 2014 | 04:04 PM
rla2005's Avatar
rla2005
CM - 111
OR
No Codes at all.
I'm glad you could read those flashes. I ran through that video several times but it kept jumping around on me.
Old Feb 17, 2014 | 04:40 PM
powerstroker100
well I shouldve known better that dmv would be closed today, I feel like a dumbell I went all the way down to the office and saw it was closed.
so I went to sears and bought a vacuum gauge and fuel pressure gauge, came back home and tested the truck, I wasnt able to adjust my tps sensor today because after playing with the gauges my back started to hurt and its about 19* out so I just got back inside
my readings were:
fuel pressure - KOEO 39psi
KOER 31psi
KOER without FPR vacuum line attached 40psi
not much change if I romped the throttle went up a couple psi, when I turned the truck off the truck didnt really drop any psi, in a little over 15 minutes it dropped 2 psi, same results on both fuel tanks
Vacuum gauge I connected to the tree on the manifold where the brake booster, FPR etc. hook up I saw 20.25in of vacuum at idle, as I slowly increased throttle it did not really change, was not jumpy or any dead spots either
let me know what you think fellas, thanks
Old Feb 17, 2014 | 06:28 PM
subford's Avatar
subford
Sounds about normal to me.
The TPS should be non adjustable.
Old Feb 17, 2014 | 06:59 PM
powerstroker100
thats great news, Maybe I'll have to replace it then to get the voltage below 1.01v
Old Feb 17, 2014 | 07:39 PM
subford's Avatar
subford
It is possible that someone has done a no-no and turned the stop screw on the throttle.
That would give a little higher idle with a higher voltage. I like to see about 0.9VDC but it can go as high as 1.0VDC.
For more information on the TPS go to this link:
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Old Feb 17, 2014 | 08:08 PM
powerstroker100
It does look like someone messed with the stop screw, I saw a clean portion of threads while the rest was all rusted where it threads into, looks like someone tried to back it off
Old Feb 17, 2014 | 08:43 PM
subford's Avatar
subford
Backing it off should let it idle down more and lower the voltage unless they went the other way to open the throttle plates.
Old Feb 17, 2014 | 09:29 PM
powerstroker100
I see, sounds like a new tps might be in order then, gonna do some more stuff tomorrow and put the truck on the road then post back
Old Feb 17, 2014 | 10:00 PM
blkF250HD's Avatar
blkF250HD
Use caution taking the TPS screws out. I got one out, snapped the head off the other. My cousin had to TIG weld a nut onto what was left so I could get it out. IIRC they're M4x1.25. Use anti-seize on reinstallation.
Old Feb 18, 2014 | 04:36 PM
  #28
powerstroker100
hey guys wanted to update this, so I got the truck on the road today and drove it around, got back home and realized its idling correctly
I think maybe from all the sitting it has done it just cleared something out while driving it and it seems fine now, has a slight miss but it has original cap+rotor,wires etc.
I know that it has those stupid bosch plugs that are like $7 a piece I really wanna get those out and put regular autolite or motorcraft plugs in
Old Feb 18, 2014 | 05:09 PM
  #29
rla2005's Avatar
rla2005
Happy to see your ride is starting to behave. Get rid of those silly plugs and get some quality ignition pieces!!
Thanks for the update
Tuff48
21
Oct 10, 2015 08:08 PM
john19999
Nov 21, 2010 08:26 AM
akoz
May 23, 2009 03:01 PM
boggerted
May 18, 2007 09:09 PM
lurchy98
1983 - 2012 Ranger & B-Series
Jun 17, 2006 03:20 PM
