cold start problems
Old Feb 14, 2014 | 01:40 PM
cbenz73's Avatar
cbenz73
cold start problems
So I have '93 ford f-250. It actually has a 6.9 with a C6 that was swapped into it. I am having some issues with cold starts. If its been sitting for a 3-5 hours or the block heater has been plugged in I get a rough running pickup with white smoke until I give her quite a bit of throttle. If its been sitting more than 8-9 hours and its cold out(its always cold out right now) I get a start an then it runs rough and stalls. Then it takes quite a bit of cranking to get it started. Im testing the glow plugs this weekend, but would like to get some input, cant hurt right?
Almost forgot, the new 6.9 is an '83
Old Feb 14, 2014 | 02:48 PM
Gettysburg150's Avatar
Gettysburg150
Someone correct me if I'm wrong, but fuel issue? Air intrusion?
If your block heater works and it runs like crap after being plugged in glow plugs aren't going to help (not saying they're good, but you can roll them out if the heater is good)
Long cranking could be air in the lines that you're working out and it will start/run ok then
Old Feb 14, 2014 | 04:24 PM
cbenz73's Avatar
cbenz73
Don't forget this is an idi, glow plugs are certainly needed whether or not you use the block heater.
Old Feb 14, 2014 | 05:05 PM
cbenz73's Avatar
cbenz73
I do see what you mean about the air intrusion, but plugging it in shouldn't eliminate a start and stall if its fuel intrusion.
Old Feb 14, 2014 | 09:02 PM
Freddyack's Avatar
Freddyack
Below 30*F usually it takes good working glow plugs and a working block heater to get a decent start.
If the glow plugs and block heater work and you are getting rough starts, then air intrusion and proper fuel flow are the next things to attack.
Old Feb 14, 2014 | 09:16 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you ain't wrong.classic symptom.
Old Feb 14, 2014 | 10:07 PM
cbenz73's Avatar
cbenz73
So I tested the glow plugs and only number 8 is bad.
mikekline316
Oct 12, 2014 08:35 PM
jcspartan117
23
Oct 10, 2012 05:29 PM
bugs
21
Dec 13, 2009 03:01 PM
Hangfire
Dec 2, 2004 11:45 PM
bullwinkle7401
Nov 6, 2003 09:52 AM
