Sponsored by: Real Truck
BDS suspension?
Old Feb 14, 2014 | 03:34 AM
macdiesell69's Avatar
macdiesell69
BDS suspension?
Hey guys thinking of putting a 4" bds 4 link suspension in my 2014 f-350, was wondering what you guys think of bds?
Old Feb 14, 2014 | 05:09 AM
2ndStroke's Avatar
2ndStroke
I don't think I've heard of any complaints, they supposably have a lifetime warranty
Old Feb 14, 2014 | 08:08 AM
jmhatchett's Avatar
jmhatchett
They are one of the best... high prices but also high quality and great support. I wouldnt hesitate to pull the trigger on anything BDS.
Old Feb 14, 2014 | 09:09 AM
macdiesell69
Ok, thanks guys. One more quick question, would you go with the 4" 4 link or the regular 4" suspension? There is about a grand difference? Thanks.
Old Feb 14, 2014 | 09:30 AM
jmhatchett's Avatar
jmhatchett
I personally wouldn't need the 4 link, I tow a lot and drive off road but to me the 4 link is more for extreme off roading.
Old Feb 14, 2014 | 10:17 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I'm a big fan of BDS hardware. If you're buying a kit from them I'd try to either opt out of shocks or sell them for Rancho adjustable sticks just because I'd like those better, but the BDS front shocks on mine are going on 40k with no issues. 4" on a Super Duty I'd do the regular kit with radius arm brackets, unless you're planning on going small with the tires so you can stuff them into the wheel wells while articulating.
Old Feb 14, 2014 | 06:01 PM
dualwheels66's Avatar
dualwheels66
My local 4x4 shop used to sell other brands and still do but they love BDS. A little more expensive but the quailty is worth the expense. Oh I would go 4 link for the better ride.
Old Feb 15, 2014 | 03:11 PM
SuperDutyScaler's Avatar
SuperDutyScaler
get the 4-link, better geometry and much better ride
Old Feb 15, 2014 | 08:27 PM
macdiesell69
Thanks for the feedback I think I will go with the 4 link if I go with bds. One more question. What should I go for rims and tires? I have stock 20" rims but was thinking 18" for aftermarket? Any suggestions and advice? Thanks a lot.
Old Feb 15, 2014 | 08:39 PM
dscabra's Avatar
dscabra
I've always heard you shouldn't go smaller than your stock wheel size, but I would say as long as you have clearance for your brakes it shouldn't be an issue.
Old Feb 16, 2014 | 10:10 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You can downsize your wheels no problem. In fact, I recommend it. 20" wheels are so common these days, but they hurt ride quality, ESPECIALLY off road. 18" is probably good. Just remember if the total diameter of the wheel and tire changes your speedometer will be off. You can have it recalibrated though.
Old Feb 16, 2014 | 08:41 PM
Woodward_Dreams's Avatar
Woodward_Dreams
You can't go wrong with BDS. I used to work at an off road shop, before getting hired at FoMoCo, and we were one of the largest BDS dealers in the country. I've installed several of these lifts on full size Fords. With that said, I HIGHLY recommend the 4 link system. Its significantly more labor intensive since the rivets in the frame have to be removed, but they its a great driving system. Definitely worth the money.
I should also note that you will want to upgrade to the Fox Shocks. If you don't do it now, you will later.
Just my .02
Don't forget to post pics if you do it
Old Feb 16, 2014 | 09:48 PM
96grimreaper's Avatar
96grimreaper
I ran BDS on my Excursion, I loved it. For a big heavy truck on all leafs, it still rode great. Like others said, upgrade the shocks and you'll be happy.
Go with a 4 link 4" on 37's on 18's. That's what I'd do if I ever lift mine.
Old Feb 17, 2014 | 05:59 PM
dualwheels66
I would go with 20" wheels if you are on the road most of the time as it will help handling and sidewall flex will be minimized. Go with 18" wheels if you wheel a lot and need sidewall flex for traction and aren't too worried about high speed handling on the highway.
Old Feb 18, 2014 | 03:26 AM
macdiesell69
Appreciate all the info, haven't decided if I'm gonna lift it or not but if I do I will most definetly go with the 4 link.
Ratkat
Aug 14, 2012 02:56 PM
84 f250 6.9
Mar 4, 2009 09:17 PM
floridadude
18
May 20, 2008 11:51 AM
ranger_4x
Jul 14, 2002 10:02 PM
