2002 excursion power seats
Old Feb 13, 2014 | 05:20 PM
espistev's Avatar
espistev
Hello members
need help!
I have a 2002 excursion XLT. it does not have power seats for the driver or passenger. I came across some power seats from a 2002 limited. what I need to know is, can I remove the non power seats and put in the seats from the limited, is the wiring already in the XLT model to just plug it in, or im I going to have to do some rewiring.
thanks
Old Feb 13, 2014 | 05:44 PM
Franklin2's Avatar
Franklin2
You will have to do some wiring. There is usually two main wires depending on the type of seats, one fat wire that is a 30 amp circuit and one smaller wire that goes to the key-on ignition circuit. I would run a separate wire through the firewall and tie the 30 amp circuit to a circuit breaker and then to the battery + directly. Use 10 gauge wire for that circuit. Find a ignition on circuit in the fuse box and use a fuse tap to put that in the fuse box. 16 gauge would be good enough for that, I think I remember it was only on a 10 amp fuse.
Old Feb 13, 2014 | 06:49 PM
espistev's Avatar
espistev
Originally Posted by espistev
Hello members
need help!
thanks
Thank you very much
I was hoping that ford laid all the wiring the same, and I could just plug it in.
Once again
Thank you
GlenInIdaho
Jan 26, 2016 03:48 PM
suburbanM3
Electrical Systems/Wiring
Apr 20, 2014 12:19 PM
wdonnamarie
Nov 3, 2012 07:18 PM
drewduncan15
Dec 18, 2011 08:38 PM
00Dave
Apr 27, 2009 02:24 PM
